moddie 2 Posted November 27, 2018 Posted November 27, 2018 (edited) Hi, couldn't find find this question anywhere, so here goes. For several months now, I've had this weird navigation problem. Unfortunately I don't know exactly anymore, when this was introduced. Currently the App reports itself as: AndroidTv 1.6.62g Running on: Sony KD-65XD7504 The Problem is as follows: 1. Navigate to any TV show episode overview page (the one with chapters and actors and so on). 2. Visit any sub page like going to an actors page or starting the episode. 3. Upon pressing back, or having the episode finish playing, the overview page is displayed again. However, I can no longer navigate using the Arrow keys. Only after returning to the main menu or the "Season N - Episodes List" navigation Focus is restored. I work around this, by using the episode list view in seasons so i'll only have to go back 2 steps to select the next episode. My NVshield does not exhibit the same behaviour. Unfortunately i have no idea where to begin debugging this, so any help would be very much appreciated. greetings Edited November 27, 2018 by moddie
ebr 16337 Posted November 27, 2018 Posted November 27, 2018 That is an odd one... I guess we can start by having you reproduce the problem and then send a log from the app. Not sure it is going to show much here but its worth a shot. Thanks.
moddie 2 Posted November 27, 2018 Author Posted November 27, 2018 (edited) Hi, I've just sent a log from the app (hopefully) I was playing Hunter x Hunter - Season 1 Ep 41. Server Version 3.5.3.0 User: MoD Also I've noticed an additional loss of focus issue: Main Menu Latest Row -> Hunter x Hunter -> go to season view for Season 1 -> select ep 41 -> start ep 41-> run a few seconds -> back -> episode view (no focus) -> back -> season view (focus OK) -> back -> Show Overview (no focus again) -> back -> Main Menu (focus is as mormal) thanks for looking into this! must be some weird edge case with whatever sony has done to android on this TV... Edited November 27, 2018 by moddie
ebr 16337 Posted November 27, 2018 Posted November 27, 2018 Okay, so this is obviously the problem: 11-27 16:42:00.217 30916 30916 W PhoneWindow: Previously focused view reported id 2131362487 during save, but can't be found during restore. Now the question is why...? I'll try to see if there is some way I can recover from that. 1
moddie 2 Posted November 27, 2018 Author Posted November 27, 2018 +1 for extreme swiftness Okay, so this is obviously the problem: 11-27 16:42:00.217 30916 30916 W PhoneWindow: Previously focused view reported id 2131362487 during save, but can't be found during restore. Now the question is why...? I'll try to see if there is some way I can recover from that.
saitoh183 137 Posted November 27, 2018 Posted November 27, 2018 (edited) +1 for extreme swiftness Hi, couldn't find find this question anywhere, so here goes. For several months now, I've had this weird navigation problem. Unfortunately I don't know exactly anymore, when this was introduced. Currently the App reports itself as: AndroidTv 1.6.62g Running on: Sony KD-65XD7504 The Problem is as follows: 1. Navigate to any TV show episode overview page (the one with chapters and actors and so on). 2. Visit any sub page like going to an actors page or starting the episode. 3. Upon pressing back, or having the episode finish playing, the overview page is displayed again. However, I can no longer navigate using the Arrow keys. Only after returning to the main menu or the "Season N - Episodes List" navigation Focus is restored. I work around this, by using the episode list view in seasons so i'll only have to go back 2 steps to select the next episode. My NVshield does not exhibit the same behaviour. Unfortunately i have no idea where to begin debugging this, so any help would be very much appreciated. greetings I have the same TV and had the same issue. Then one day i came to try it and it was working fine. I didnt need to press up twice on my remote to regain some kind of focus. im Not home at the moment but when i get in, i will try again. Edited November 27, 2018 by saitoh183
moddie 2 Posted November 30, 2018 Author Posted November 30, 2018 Hello, just wanted to do my due dilligence and re-install the app. The Version has changed to 1.6.64g now and the focus issue is apparently resolved. Did you update the app already? Just hope I didn't waste your time looking at this. greetings Ben
