kxtream 3 Posted February 28, 2024 Posted February 28, 2024 17 minutes ago, alucryd said: Yes see images when I click "FFMPEG" it shows lock-3 see in order its blank on lock-2 which is Emby Media
Luke 42234 Posted February 28, 2024 Posted February 28, 2024 7 minutes ago, kxtream said: it installed fine. now issue is when I go to localip:8096 it is blank like nothing loads IDK if the index has anything to this one or it is my server Is any emby server log file created? How to Report a Problem
kxtream 3 Posted February 28, 2024 Posted February 28, 2024 3 minutes ago, Luke said: Is any emby server log file created? How to Report a Problem let me look I dont think honestly it has any logs besides the system logs which I checked
alucryd 318 Posted February 28, 2024 Posted February 28, 2024 On Thecus, logs should be in /raid/data/module/EmbyServer/programdata/logs.
kxtream 3 Posted February 28, 2024 Posted February 28, 2024 9 minutes ago, alucryd said: On Thecus, logs should be in /raid/data/module/EmbyServer/programdata/logs. Ok I have to hook up a monitor as from web UI or FTP I can't see that or them folders you listed I see _Module_Folder_ with EmbyServer but that folder is blank
alucryd 318 Posted February 29, 2024 Posted February 29, 2024 11 hours ago, kxtream said: Ok I have to hook up a monitor as from web UI or FTP I can't see that or them folders you listed I see _Module_Folder_ with EmbyServer but that folder is blank Logging in via SSH is going to be easier than both of these methods.
kxtream 3 Posted March 1, 2024 Posted March 1, 2024 On 2/29/2024 at 3:26 AM, alucryd said: Logging in via SSH is going to be easier than both of these methods. ok after logging in how do I save the log? sorry first time with a Thecus
kxtream 3 Posted March 2, 2024 Posted March 2, 2024 10 hours ago, Luke said: So you were able to get to the folder via ssh? I will check right now give me a few 1
kxtream 3 Posted March 3, 2024 Posted March 3, 2024 On 3/1/2024 at 11:53 AM, Luke said: So you were able to get to the folder via ssh? I found it but its blank
bdowns83 7 Posted March 25, 2024 Posted March 25, 2024 This setup works: Not sure if this helps or adds noise... but I'm running Emby Server 4.8.3 on Thecus N7700PROv2 Firmware Version: 2.06.03.v2. dserve:~# grep model /proc/cpuinfo model : 15 model name : Intel(R) Core(TM)2 Duo CPU T5500 @ 1.66GHz model : 15 model name : Intel(R) Core(TM)2 Duo CPU T5500 @ 1.66GHz I'm also running rSyslog app on Thecus. Logging is working fine. dserve:/raid/data/module/EmbyServer/programdata/logs# more embyserver.txt 2024-03-25 00:00:00.054 Info App: Emby Server Version: 4.8.3.0 2024-03-25 00:00:00.054 Info App: Emby Command line: /raid0/data/module/EmbyServer/sys/system/EmbyServer.dll -p rogramdata /raid/data/module/EmbyServer/programdata -ffdetect /raid/data/module/ EmbyServer/sys/bin/ffdetect -ffmpeg /raid/data/module/EmbyServer/sys/bin/ffmpeg -ffprobe /raid/data/module/EmbyServer/sys/bin/ffprobe -defaultdirectory /raid/NA S_Public -updatepackage emby-server-thecus_{version}_x86_64.mod -noautorunwebapp Operating system: Linux version 3.14.79 (root@localhost.localdomain) (gc c version 4.9.3 (GCC) ) #1 SMP Wed Jul 18 17:29:40 CST 2018 Framework: .NET 6.0.25 OS/Process: x64/x64 Runtime: raid0/data/module/EmbyServer/sys/system/System.Private.CoreLib. dll Processor count: 2 Data path: /raid/data/module/EmbyServer/programdata Application path: /raid0/data/module/EmbyServer/sys/system 2024-03-25 00:00:00.054 Info App: Logs path: /raid/data/module/EmbyServer/progra mdata/logs 2024-03-25 00:00:00.054 Info App: Cache path: /raid/data/module/EmbyServer/progr amdata/cache 1
