Abobader 3485 Posted April 21, 2014 Posted April 21, 2014 Abo, it is a long shot but try version 152. Good day Ebr, Well same issue: http://paste2.org/hdbsVfw0 I will reboot my pc tonight as well try to see what the problem, since the mb3 server and mbc are on the same PC. My best
ebr 16334 Posted April 21, 2014 Author Posted April 21, 2014 I don't know what is going on on your system Abo. We are unable to get a response from the MPC-HC web interface and the error we are getting makes no sense because it happens on the very first activity: 2014-04-21 07:24:32.2291,Debug,,Creating new web client for MPC-HC,49,Worker thread for Wait for external player to launch 2014-04-21 07:24:34.6013,Error,,Error connecting to MPC-HC web interface at: http://localhost:13579/status.html ( Exception. Type=System.NotSupportedException Msg=WebClient does not support concurrent I/O operations. Src=System Method=ClearWebClientState Line=0 Col=0 [n] StackTrace= [n] at System.Net.WebClient.ClearWebClientState() [n] at System.Net.WebClient.DownloadStringAsync(Uri address,, Object userToken) [n] at MediaBrowser.Library.Playables.MpcHc.MpcHcPlaybackController.MonitorStatus() ),50,
Abobader 3485 Posted April 21, 2014 Posted April 21, 2014 I don't know what is going on on your system Abo. We are unable to get a response from the MPC-HC web interface and the error we are getting makes no sense because it happens on the very first activity: 2014-04-21 07:24:32.2291,Debug,,Creating new web client for MPC-HC,49,Worker thread for Wait for external player to launch 2014-04-21 07:24:34.6013,Error,,Error connecting to MPC-HC web interface at: http://localhost:13579/status.html ( Exception. Type=System.NotSupportedException Msg=WebClient does not support concurrent I/O operations. Src=System Method=ClearWebClientState Line=0 Col=0 [n] StackTrace= [n] at System.Net.WebClient.ClearWebClientState() [n] at System.Net.WebClient.DownloadStringAsync(Uri address,, Object userToken) [n] at MediaBrowser.Library.Playables.MpcHc.MpcHcPlaybackController.MonitorStatus() ),50, Good day Ebr, I just found out that the web interface not enable at mpc-hc, I thought that was enable within the Media Browser Classic Configurator when editing the external player by applying the "configure my player", but seem it do not have any effect on it lately. So I enable it and all working as it should, here my last MBC Configurator log: 2014-04-21 07:15:20.0519,Debug,,=========System looking for assembly: Newtonsoft.Json,, Version=4.5.0.0,, Culture=neutral,, PublicKeyToken=30ad4fe6b2a6aeed,1, 2014-04-21 07:15:20.0549,Info,,Resolving Newtonsoft.Json,, Version=4.5.0.0,, Culture=neutral,, PublicKeyToken=30ad4fe6b2a6aeed to C:\ProgramData\MediaBrowser-Classic\Newtonsoft.Json.dll,1, 2014-04-21 07:15:20.0919,Info,,Sending Http Get to http://192.168.1.20:8099/mediabrowser/System/Info?format=Json,1, 2014-04-21 07:15:33.9493,Info,,Sending Http Get to http://192.168.1.20:8099/mediabrowser/System/Configuration?format=Json,1, 2014-04-21 07:15:34.0623,Info,,Sending Http Get to http://192.168.1.20:8099/mediabrowser/Plugins?format=Json,1, 2014-04-21 07:15:34.0913,Info,,====== Connected to server 192.168.1.20:8099,1, 2014-04-21 07:15:34.0943,Info,,Sending Http Get to http://192.168.1.20:8099/mediabrowser/Users/Public?isDisabled=False&format=Json,1, 2014-04-21 07:15:34.1713,Debug,,=========System looking for assembly: System.Data.SQLite,, Version=1.0.61.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139,1, 2014-04-21 07:15:34.1723,Info,,System.Data.SQLite,, Version=1.0.61.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139 is being resolved to System.Data.SQLite,, Version=1.0.88.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139,1, 2014-04-21 07:15:34.1763,Info,,==========Using new SQL Repo========,1, 2014-04-21 07:15:34.5113,Info,,Playstate initialization took 0.01 seconds.,1, 2014-04-21 07:15:34.5603,Info,,Using String Data from C:\ProgramData\MediaBrowser-Classic\Localization\strings-en.xml,1, 2014-04-21 07:15:34.5753,Info,,Successfully loaded fastload data for : C:\ProgramData\MediaBrowser-Classic\Cache\playstate MediaBrowser.Library.Entities.PlaybackStatus,9,Worker thread for Fast Load Loader 2014-04-21 07:15:34.5893,Debug,,=========System looking for assembly: MediaBrowser,, Version=3.0.148.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64,1, 2014-04-21 07:15:34.5893,Info,,Plug-in reference to MediaBrowser,, Version=3.0.148.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64 is being linked to version 3.0.151.0,1, 2014-04-21 07:15:34.5923,Debug,,Added Plugin assembly: Chocolate,, Version=3.0.5.2,, Culture=neutral,, PublicKeyToken=cbacf2b624ff6ad4,1, 2014-04-21 07:15:34.5943,Debug,,=========System looking for assembly: MediaBrowser,, Version=3.0.143.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64,1, 2014-04-21 07:15:34.5943,Info,,Plug-in reference to MediaBrowser,, Version=3.0.143.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64 is being linked to version 3.0.151.0,1, 2014-04-21 07:15:34.6003,Debug,,=========System looking for assembly: MediaBrowser.Model,, Version=3.0.5190.17693,, Culture=neutral,, PublicKeyToken=6cde51960597a7f9,1, 2014-04-21 07:15:34.6003,Info,,Resolving MediaBrowser.Model,, Version=3.0.5190.17693,, Culture=neutral,, PublicKeyToken=6cde51960597a7f9 to C:\ProgramData\MediaBrowser-Classic\MediaBrowser.Model.dll,1, 2014-04-21 07:15:34.6013,Debug,,Added Plugin assembly: GameBrowser-Classic,, Version=3.0.0.38,, Culture=neutral,, PublicKeyToken=307c6ce4e08b837b,1, 2014-04-21 07:15:34.6033,Debug,,=========System looking for assembly: MediaBrowser,, Version=3.0.64.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64,1, 2014-04-21 07:15:34.6033,Info,,Plug-in reference to MediaBrowser,, Version=3.0.64.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64 is being linked to version 3.0.151.0,1, 2014-04-21 07:15:34.6043,Debug,,Added Plugin assembly: MBBookshelf-Classic,, Version=1.0.0.5,, Culture=neutral,, PublicKeyToken=307c6ce4e08b837b,1, 2014-04-21 07:15:34.6123,Info,,Not creating menus for Chocolate. Appear to not be in MediaCenter. AppDomain is: Configurator.exe,1, 2014-04-21 07:15:34.6233,Info,,Using String Data from C:\ProgramData\MediaBrowser-Classic\Localization\Chocolate-strings-en.xml,1, 2014-04-21 07:15:34.6423,Error,,Error appending fonts file ( Exception. Type=System.NullReferenceException Msg=Object reference not set to an instance of an object. Src=MediaBrowser Method=AppendFonts Line=0 Col=0 [n] StackTrace= [n] at MediaBrowser.Library.Util.CustomResourceManager.AppendFonts(String prefix,, Byte[] stdFontResource,, Byte[] smallFontResource) ),1, 2014-04-21 07:15:34.6453,Info,,Finished validating : C:\ProgramData\MediaBrowser-Classic\Cache\playstate MediaBrowser.Library.Entities.PlaybackStatus,9,Worker thread for Fast Load Loader 2014-04-21 07:15:34.6453,Info,,Dictionary loading and validation took 0.14 seconds.,9,Worker thread for Fast Load Loader 2014-04-21 07:15:34.6503,Info,,Chocolate Theme (version 3.0.5.2) Loaded.,1, 2014-04-21 07:15:34.6553,Debug,,*** GAMEBROWSER *** Settings file exists: checking for root element match,1, 2014-04-21 07:15:34.6563,Debug,,*** GAMEBROWSER *** Load settings,1, 2014-04-21 07:15:34.6683,Info,,Sending Http Get to http://192.168.1.20:8099/mediabrowser/Plugins/RegistrationRecords/gamebrowser-classic?Mb2Equivalent=gamebrowser-classic&format=Json,12,Worker thread for gamebrowser-classic registration check 2014-04-21 07:15:34.6683,Debug,,=========System looking for assembly: GameBrowser-Classic.XmlSerializers,, Version=3.0.0.38,, Culture=neutral,, PublicKeyToken=307c6ce4e08b837b,1, 2014-04-21 07:15:34.8564,Info,,GameBrowser-Classic (version 3.0.0.38) Plug-in Loaded.,1, 2014-04-21 07:15:34.8574,Info,,MBBookshelf_Classic (version 1.0.0.5) Plug-in Loaded.,1, 2014-04-21 07:15:34.8574,Info,,Plugin Loading and Init took 0.28 seconds.,1, 2014-04-21 07:15:34.8574,Debug,,======= Kernel intialized. Building window...,1, 2014-04-21 07:15:35.1764,Info,,Sending Http Get to http://192.168.1.20:8099/mediabrowser/Packages?packagetype=UserInstalled&targetsystems=MBClassic&format=Json,1, 2014-04-21 07:15:39.8669,Error,,Registration checked,14,Worker thread for GameBrowser Registration Check 2014-04-21 07:15:39.8689,Info,,GameBrowser-Classic Registration confirmed.,14,Worker thread for GameBrowser Registration Check 2014-04-21 07:15:43.9533,Debug,,=========System looking for assembly: MediaBrowser,, Version=3.0.129.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64,1, 2014-04-21 07:15:43.9533,Info,,Plug-in reference to MediaBrowser,, Version=3.0.129.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64 is being linked to version 3.0.151.0,1, 2014-04-21 07:15:48.3787,Info,,Sending Http Get to http://192.168.1.20:8099/mediabrowser/System/Info?format=Json,1, 2014-04-21 07:15:48.5087,Info,,Sending Http Get to http://192.168.1.20:8099/mediabrowser/Packages/MBClassic?format=Json,1, My best 1
ebr 16334 Posted April 22, 2014 Author Posted April 22, 2014 Build 154 includes just a few more small fixes with external players and performance issues associated with the dreaded "Hide Empty Folders" option. 1
ebr 16334 Posted April 24, 2014 Author Posted April 24, 2014 Dev build 156 includes support for multi-part movies. EDIT: I accidentally put up a debug version the first time so, if you get a debug prompt, un-install and re-install. Sorry. 1
Xzener 729 Posted April 24, 2014 Posted April 24, 2014 Great work Ebr... Wish I hadn't merged all my multi part movies to play as singular.
ebr 16334 Posted April 29, 2014 Author Posted April 29, 2014 159 introduces a new Exit Menu that keeps you from accidentally backing out of the application and also provides the ability to either log out or put the machine to sleep. 4
sydlexius 300 Posted April 30, 2014 Posted April 30, 2014 Thank you! 159 introduces a new Exit Menu that keeps you from accidentally backing out of the application and also provides the ability to either log out or put the machine to sleep.
