kcchesnut 0 Posted November 27, 2018 Posted November 27, 2018 (edited) New to emby. Got it setup and running (2x Synology) and starting to explore settings. I want to enable Collections. If I go to Library - Display, I only see 2 options (specials per season, external content suggestions) Per the wiki, i'm expecting to see an options to Display collections and Group collections. I want to set a pin, but if I open my user, I only see the ability to change password. Per the wiki, I was expecting to see the option to set an Easy Pin edit: found this answer here: https://emby.media/community/index.php?/topic/33105-easy-pin-question/ I'm assuming my user account is somehow messed up. Wondering if its because my Connect and User names are the same? Thanks, casey Edited November 27, 2018 by kcchesnut
Happy2Play 9806 Posted November 27, 2018 Posted November 27, 2018 What server version are you running? How are you connecting to Emby? I can only assume with your description it is via app.emby.media. Do to the online web client using newer code then the current stable release there is no way to enable "Group items into collections" via app.emby.media. You would have to log into your server via localhost/lanip:port, and you will see the option in Library-Display. It has moved to a per library option in the next release (3.6).
kcchesnut 0 Posted November 27, 2018 Author Posted November 27, 2018 v3.5.3.0 Connecting through Nvidia Shield and app.emby.com for testing. Screenshot below shows that collection options aren't showing. Will try again v3.6 Thanks
Luke 42216 Posted November 27, 2018 Posted November 27, 2018 Yes, the collections options will be directly in the UI in 3.6. Thanks.
kcchesnut 0 Posted November 27, 2018 Author Posted November 27, 2018 Great. As a workaround, I installed Auto Box Sets plugin, and that added Collections to my Library.
