westmichigansc 0 Posted November 26, 2018 Posted November 26, 2018 I am starting to connect more devices and computers to my emby server, Xbox One, Roku, Another PC or laptop. I get a connection error screen saying it was unable to connect to the selected server right now and to make sure the server is turned on. It is on. It generally works on the computer that is running the server. All of the devices are using the same wifi connection as the server. The other computers mostly don't connect and get the connection error including Xbox One. So far Roku seems to be connecting good. Do I need to go in to the computer running the server and restart it before connecting, or is there some setting that I need to allow the others to connect to the server? Any help is appreciated to resolve this!
Luke 42216 Posted November 26, 2018 Posted November 26, 2018 Hi there, I would suggest checking out our Connection Troubleshooter: https://github.com/MediaBrowser/Wiki/wiki/Connectivity Please try the steps listed there and let us know which ones succeed and which ones do not. Thanks !
