WooAf 0 Posted November 26, 2018 Posted November 26, 2018 I've been using Backup & Restore from the Plugins Catalog and the backup created is missing some of my users.. How I can do a full backup / restore ? Thanks
ebr 16312 Posted November 26, 2018 Posted November 26, 2018 Hi. The Backup plug-in will not backup or restore users that were only invited via email (Connect). It can only backup local users. We are looking to re-vamp the user area in the future to make this less complex. Does that answer your question? 1
WooAf 0 Posted November 26, 2018 Author Posted November 26, 2018 Hi. The Backup plug-in will not backup or restore users that were only invited via email (Connect). It can only backup local users. We are looking to re-vamp the user area in the future to make this less complex. Does that answer your question? Is there a way to restore their watched history if I invite them in my new server ?
Luke 42216 Posted November 26, 2018 Posted November 26, 2018 Yes, when you restore with the backup plugin, uncheck all the restore options except for restoring user data. Then configure the user data restore process for each user you want to do it for.
WooAf 0 Posted November 26, 2018 Author Posted November 26, 2018 Yes, when you restore with the backup plugin, uncheck all the restore options except for restoring user data. Then configure the user data restore process for each user you want to do it for. Yes but the Backup plug-in will not backup or restore users that were only invited via email .. is there a way to restore users that were invited via email ?
ebr 16312 Posted November 26, 2018 Posted November 26, 2018 Yes but the Backup plug-in will not backup or restore users that were only invited via email .. is there a way to restore users that were invited via email ? No, but, once you re-create the user in the new setup, run the restore again and un-check everything except the user data you want. You can restore any previous user's data into any user on the new server.
