maegibbons 1287 Posted January 22, 2019 Author Posted January 22, 2019 No. I had to buy a shield because it was not working!!! Krs Mark 1
maegibbons 1287 Posted January 22, 2019 Author Posted January 22, 2019 Just tried it. No it does not work unless there are sewttings that need to be changed. Krs Mark
maegibbons 1287 Posted January 22, 2019 Author Posted January 22, 2019 It does if you enable "Refresh Rate Switching" Krs Mark
maegibbons 1287 Posted January 22, 2019 Author Posted January 22, 2019 (edited) BUT HDR is not being triggered Close but no cigar! Krs Mark Edited January 22, 2019 by maegibbons
ebr 16338 Posted January 22, 2019 Posted January 22, 2019 It does if you enable "Refresh Rate Switching" Krs Mark Yes because that is actually "Display mode switching" but most people probably wouldn't understand that. As for HDR, I'm really not sure that is supported in this version of Android...
maegibbons 1287 Posted January 22, 2019 Author Posted January 22, 2019 Yes because that is actually "Display mode switching" but most people probably wouldn't understand that. As for HDR, I'm really not sure that is supported in this version of Android... I believe HDR works fine with Amazon prime and other apps. I will Check and confirm this later. Krs Mark
ebr 16338 Posted January 22, 2019 Posted January 22, 2019 Make sure whatever you are testing with is a full-frame video (not cropped).
maegibbons 1287 Posted January 23, 2019 Author Posted January 23, 2019 Yes because that is actually "Display mode switching" but most people probably wouldn't understand that. As for HDR, I'm really not sure that is supported in this version of Android... @@ebr You are correct. Whilst HEVC is supported on the Fire TV (Gen 2) - HDR is not!. Many thanks for supporting HEVC Krs Mark
