yhq_34 0 Posted November 26, 2018 Posted November 26, 2018 Hi, Can I play movie through PS4 media player (DLNA),now cannot found emby server on the player. And I found web browser need time to load and not convenient as media player.
Nickbert 7 Posted November 26, 2018 Posted November 26, 2018 Hi,I have noticed a similar issue.Sometimes I must disable and enable the DLNA server in the EMBY server settings, so it can be found by the PS4 again.
yhq_34 0 Posted November 26, 2018 Author Posted November 26, 2018 What cause need manually disable and enable in the DLNA server in the EMBY server settings?
Luke 42239 Posted November 26, 2018 Posted November 26, 2018 Hi, it's hard to say why you might have disabled it, but I'm glad you found it. Thanks !
Nickbert 7 Posted November 26, 2018 Posted November 26, 2018 Maybe we have a misunderstanding here. In my case the DLNA feature is enabled all the time. But sometimes (I do not really often use the PS4 with EMBY so it is not a big issue for me) the server cannot be found anymore by the PS4. To get it visible within the Mediaplayer again, I have to disable and enable the feature. What cause need manually disable and enable in the DLNA server in the EMBY server settings? Was it the same in your case?
Luke 42239 Posted November 26, 2018 Posted November 26, 2018 The server sends out notifications across your network every 30 minutes. you could try increasing that frequency in dlna settings.
yhq_34 0 Posted November 27, 2018 Author Posted November 27, 2018 I changed to 30 seconds, seems still need time to appear, but plex no need have time to wait.
