telemarker7 1 Posted November 24, 2018 Posted November 24, 2018 I've just given up trying to get Emby working in Docker (I'm a docker newb) and got it working as a stand alone install on my server in minutes. I'm happy to write a tutorial on how to get things working but the docker hub guide just leaves me at a loss. I've installed the latest docker and I easily got Portainer up and running. I can manage the pull from the docker hub. docker pull emby/embyserver:latest However when faced with the next step I'm at a loss docker run -d \ --volume /path/to/programdata:/config \ # This is mandatory --volume /path/to/share1:/mnt/share1 \ # To mount a first share --volume /path/to/share2:/mnt/share2 \ # To mount a second share --device /dev/dri/renderD128 \ # To mount a render node for VAAPI --publish 8096:8096 \ # To expose the HTTP port --publish 8920:8920 \ # To expose the HTTPS port --env UID=1000 \ # The UID to run emby as (default: 2) --env GID=100 \ # The GID to run emby as (default 2) --env GIDLIST=100 \ # A comma-separated list of additional GIDs to run emby as (default: 2) emby/embyserver:latest I can manage the first line, but what is my path to programdata? I know where my mounts are, but the : syntax separating the source from the mount is confusing. I guess that the VAAPI line doesn't need to change, but after the three volume lines I don't know. The port lines make sense, but someone more newb than me would need help. I can manage the UID and GIDs but once again I'm sure there are plenty who would be stumped. I'm happy to write a guide for the ignorant like me, but I need help getting Emby to work in docker first. 1
Hitsville 37 Posted November 24, 2018 Posted November 24, 2018 I'm having the same issues so I'm gonna follow this like a hawk. (Also new to docker.) I'm my case I'm using the Gooby script here. https://github.com/TechPerplexed/Gooby/wiki It's pretty awesome but just will not update Emby at all. Sent from my SM-G935F using Tapatalk
Luke 42216 Posted November 24, 2018 Posted November 24, 2018 Why not just use the default values that are listed there in the doc?
