LocutusDeBorg 0 Posted November 23, 2018 Posted November 23, 2018 Hello, I'm trying to run Emby downloaded from the the emby.media website (QNAS/X31P version, named: embyserver*x41.qpkg). It installs fine but does not start. When I start it from the command line, it immediately returns with a segfault. Also, I noticed that the ffmpeg binaries in the .qnap/EnbyServer/bin directory fail with: bin/ffmpeg: error while loading shared libraries: libavdevice.so.58: cannot open shared object file: No such file or directory If I add LD_LIBRARY_PATH=<installdir>/lib:<installdir>/lib/samba to the command, ffmpeg segfaults too Am I running the correct package? If not, is there a recent version for my NAS? Thanks in advance, LDB
Luke 42240 Posted November 23, 2018 Posted November 23, 2018 Hi, this has an armv7 cpu, is that correct?
LocutusDeBorg 0 Posted November 23, 2018 Author Posted November 23, 2018 Not sure...Here is what's reported by /proc/cpuinfo: processor : 0 model name : Annapurna Labs Alpine AL212 Dual-core ARM Cortex-A15 CPU @ 1.70GHz Speed : 1.7GHz Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm CPU implementer : 0x41 CPU architecture: 7 CPU variant : 0x2 CPU part : 0xc0f CPU revision : 4
Luke 42240 Posted November 23, 2018 Posted November 23, 2018 Can you attach the emby server log? You can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks !
LocutusDeBorg 0 Posted November 23, 2018 Author Posted November 23, 2018 The <install_dr>/programdata directory is completely empty.
Luke 42240 Posted November 23, 2018 Posted November 23, 2018 Then how do you even get to the point of trying to play something and getting that ffmpeg error?
LocutusDeBorg 0 Posted November 23, 2018 Author Posted November 23, 2018 I ran it from the command line. I tried to start bin/emby-server manually (it segfaulted) I then noticed the other ff* files in the <install_dir>/bin directory. So, as an experiment, I tried to run one (ffmpeg). It gave the shared library missing error. From there, I ran ffmpeg w/ the addition of the LD_LIBRARY_PATH on the command line (instead of messing w/ my /etc/ld.so.conf file). That's when ffmpeg segfaults.
Luke 42240 Posted November 23, 2018 Posted November 23, 2018 Got it OK, thanks for the info. We'll see if we can chase this down.
alucryd 318 Posted November 24, 2018 Posted November 24, 2018 @@LocutusDeBorg Could you look into /lib on your NAS and share the libc version it has, you should look for a ld-2.2x.so file, 2.2x is the version.
LocutusDeBorg 0 Posted November 24, 2018 Author Posted November 24, 2018 Yep...I'm on the latest firmware for this model (updated this week)
TheLizard 0 Posted November 25, 2018 Posted November 25, 2018 I'm having the same issue. cpuinfo: Processor name : ARMv7 Processor rev 1 (v7l) processor : 0 BogoMIPS : 2387.14 processor : 1 BogoMIPS : 2393.70 Features : swp half thumb fastmult vfp edsp neon vfpv3 tls CPU implementer : 0x41 CPU architecture: 7 CPU variant : 0x2 CPU part : 0xc09 CPU revision : 1 Hardware : Comcerto 2000 EVM Revision : 0001 Serial : 0000000000000000 I've also installed the latest firmware: Model: TS-231 Current firmware version: 4.3.5.0760 Date: 11/14/2018 However, the libc version is even older: ld-2.14.1.so libc-2.14.1.so
Luke 42240 Posted November 25, 2018 Posted November 25, 2018 Wow, libc 2.14. Ultimately this means we are going to have to compile against older libcs, which can be a challenge. We are looking into this. Thanks.
alucryd 318 Posted November 26, 2018 Posted November 26, 2018 Well, Qnap doesn't even provide an armv7 toolchain, only armv5... https://sourceforge.net/projects/qosgpl/files/QNAP%20NAS%20Tool%20Chains/ And good luck finding any viable toolchain with these kind of ancient versions. But before we do anything, I just produced packages with our own glibc, these will hopefully work on any armv7 model.
LocutusDeBorg 0 Posted November 26, 2018 Author Posted November 26, 2018 Thanks. Mixed news. I installed the package using the QNAP UI. The emby-server didn't automatically start. I attempted to start it from the command line: Segfault. I then used the LD_LIBRARY_PATH. Same result. From there, I invoked your packaged library loader directly with the following result: # ./lib/ld-linux-armhf.so.3 --library-path ./lib:./lib/samba ./bin/emby-server ./bin/emby-server: error while loading shared libraries: ./bin/emby-server: invalid ELF header The good news: I was able to get your ff* binaries to run using this method.
LocutusDeBorg 0 Posted November 26, 2018 Author Posted November 26, 2018 A bit more info: I commented out the LD_LIBRARY_PATH variable in the bin/emby-server wrapper script (emby*.71_arm.qpkg). I got: FailFast: Couldn't find a valid ICU package installed on the system. Set the configuration flag System.Globalization.Invariant to true if you want to run with no globalization support. at System.Environment.FailFast(System.String) at System.Globalization.GlobalizationMode.GetGlobalizationInvariantMode() at System.Globalization.GlobalizationMode..cctor() at System.Globalization.CultureData.CreateCultureWithInvariantData() at System.Globalization.CultureData.get_Invariant() at System.Globalization.CultureInfo..cctor() at System.StringComparer..cctor() at System.AppDomain.InitializeCompatibilityFlags() at System.AppDomain.CreateAppDomainManager() at System.AppDomain.Setup(System.Object) Aborted So I added (to system/EmbyServer.runtimeconfig.json): "configProperties": { "System.Globalization.Invariant": true } It looked like the server was going to start, but ended in a stack trace too long to post (SQLitePCLRaw.provider.sqlite3 as the source).
Luke 42240 Posted November 26, 2018 Posted November 26, 2018 Hi, are you really not able to provide that stack trace, or some of it? Thanks.
LocutusDeBorg 0 Posted November 26, 2018 Author Posted November 26, 2018 Info Main: Application path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll Info Main: Emby Command line: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll -programdata /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata -ffdetect /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffdetect -ffmpeg /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg -ffprobe /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffprobe -defaultdirectory /share/CACHEDEV1_DATA -updatepackage emby-server-qnap_{version}_x86_64.qpkg Operating system: Unix 4.2.8.0 64-Bit OS: False 64-Bit Process: False User Interactive: True Processor count: 4 Program data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system Info App: Application version: 3.6.0.71 Info App: Loading assemblies Info App: File /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata/plugins/Fanart.dll has version 1.0.1.0 Info App: File /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/plugins/Fanart.dll has version 1.0.1.0 Info App: File /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata/plugins/MovieDb.dll has version 1.0.2.0 Info App: File /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/plugins/MovieDb.dll has version 1.0.2.0 Info App: File /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata/plugins/OpenSubtitles.dll has version 1.0.9.0 Info App: File /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/plugins/OpenSubtitles.dll has version 1.0.9.0 Info App: File /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata/plugins/Emby.Server.CinemaMode.dll has version 1.0.6.0 Info App: File /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/plugins/Emby.Server.CinemaMode.dll has version 1.0.6.0 Info App: File /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata/plugins/MusicBrainz.dll has version 1.0.1.0 Info App: File /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/plugins/MusicBrainz.dll has version 1.0.1.0 Info App: File /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata/plugins/AudioDb.dll has version 1.0.3.0 Info App: File /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/plugins/AudioDb.dll has version 1.0.3.0 Info App: File /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata/plugins/NfoMetadata.dll has version 1.0.10.0 Info App: File /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/plugins/NfoMetadata.dll has version 1.0.10.0 Info App: File /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata/plugins/OMDb.dll has version 1.0.3.0 Info App: File /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/plugins/OMDb.dll has version 1.0.3.0 Info App: Loading Fanart, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null from /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata/plugins/Fanart.dll Info App: Loading MovieDb, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null from /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata/plugins/MovieDb.dll Info App: Loading OpenSubtitles, Version=1.0.9.0, Culture=neutral, PublicKeyToken=null from /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata/plugins/OpenSubtitles.dll Info App: Loading Emby.Server.CinemaMode, Version=1.0.6.0, Culture=neutral, PublicKeyToken=null from /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata/plugins/Emby.Server.CinemaMode.dll Info App: Loading MusicBrainz, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null from /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata/plugins/MusicBrainz.dll Info App: Loading AudioDb, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null from /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata/plugins/AudioDb.dll Info App: Loading NfoMetadata, Version=1.0.10.0, Culture=neutral, PublicKeyToken=null from /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata/plugins/NfoMetadata.dll Info App: Loading OMDb, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null from /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata/plugins/OMDb.dll Info App: Loading MediaBrowser.Api, Version=3.6.0.71, Culture=neutral, PublicKeyToken=null Info App: Loading MediaBrowser.WebDashboard, Version=3.6.0.71, Culture=neutral, PublicKeyToken=null Info App: Loading MediaBrowser.Model, Version=3.6.0.71, Culture=neutral, PublicKeyToken=null Info App: Loading MediaBrowser.Common, Version=3.6.0.71, Culture=neutral, PublicKeyToken=null Info App: Loading MediaBrowser.Controller, Version=3.6.0.71, Culture=neutral, PublicKeyToken=null Info App: Loading MediaBrowser.Providers, Version=3.6.0.71, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Photos, Version=3.6.0.71, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Server.Implementations, Version=3.6.0.71, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.LiveTV, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Server.MediaEncoding, Version=3.6.0.71, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Dlna, Version=3.6.0.71, Culture=neutral, PublicKeyToken=null Info App: Loading MediaBrowser.LocalMetadata, Version=3.6.0.71, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Notifications, Version=3.6.0.71, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Codecs, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Server.Connect, Version=3.6.0.71, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Server.Sync, Version=3.6.0.71, Culture=neutral, PublicKeyToken=null Info App: Loading EmbyServer, Version=3.6.0.71, Culture=neutral, PublicKeyToken=null Error Main: Error in appHost.Init *** Error Report *** Version: 3.6.0.71 Command line: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll -programdata /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata -ffdetect /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffdetect -ffmpeg /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg -ffprobe /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffprobe -defaultdirectory /share/CACHEDEV1_DATA -updatepackage emby-server-qnap_{version}_x86_64.qpkg Operating system: Unix 4.2.8.0 64-Bit OS: False 64-Bit Process: False User Interactive: True Processor count: 4 Program data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.TypeInitializationException: System.TypeInitializationException: The type initializer for 'Emby.Sqlite.BaseSqliteRepository' threw an exception. ---> System.EntryPointNotFoundException: Unable to find an entry point named 'sqlite3_config' in shared library 'sqlite3'. at SQLitePCL.SQLite3Provider_sqlite3.NativeMethods.sqlite3_config_int(Int32 op, Int32 val) at SQLitePCL.SQLite3Provider_sqlite3.SQLitePCL.ISQLite3Provider.sqlite3_config(Int32 op, Int32 val) at SQLitePCL.raw.sqlite3_config(Int32 op, Int32 val) at Emby.Sqlite.BaseSqliteRepository..cctor() --- End of inner exception stack trace --- at Emby.Sqlite.BaseSqliteRepository..ctor(ILogger logger) at Emby.Server.Implementations.Data.SqliteUserRepository..ctor(ILogger logger, IServerApplicationPaths appPaths, IJsonSerializer jsonSerializer) at Emby.Server.Implementations.ApplicationHost.GetUserRepository() at Emby.Server.Implementations.ApplicationHost.RegisterResources(FfmpegConfiguration ffmpegInfo) at Emby.Server.Implementations.ApplicationHost.Init() at EmbyServer.Program.InitAppHost(CoreAppHost appHost, ILogger logger) Source: Emby.Sqlite TargetSite: Void .ctor(MediaBrowser.Model.Logging.ILogger) at Emby.Sqlite.BaseSqliteRepository..ctor(ILogger logger) at Emby.Server.Implementations.Data.SqliteUserRepository..ctor(ILogger logger, IServerApplicationPaths appPaths, IJsonSerializer jsonSerializer) at Emby.Server.Implementations.ApplicationHost.GetUserRepository() at Emby.Server.Implementations.ApplicationHost.RegisterResources(FfmpegConfiguration ffmpegInfo) at Emby.Server.Implementations.ApplicationHost.Init() at EmbyServer.Program.InitAppHost(CoreAppHost appHost, ILogger logger) InnerException: System.EntryPointNotFoundException: Unable to find an entry point named 'sqlite3_config' in shared library 'sqlite3'. Source: SQLitePCLRaw.provider.sqlite3 TargetSite: Int32 sqlite3_config_int(Int32, Int32) at SQLitePCL.SQLite3Provider_sqlite3.NativeMethods.sqlite3_config_int(Int32 op, Int32 val) at SQLitePCL.SQLite3Provider_sqlite3.SQLitePCL.ISQLite3Provider.sqlite3_config(Int32 op, Int32 val) at SQLitePCL.raw.sqlite3_config(Int32 op, Int32 val) at Emby.Sqlite.BaseSqliteRepository..cctor() Error Main: UnhandledException *** Error Report *** Version: 3.6.0.71 Command line: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll -programdata /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata -ffdetect /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffdetect -ffmpeg /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg -ffprobe /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffprobe -defaultdirectory /share/CACHEDEV1_DATA -updatepackage emby-server-qnap_{version}_x86_64.qpkg Operating system: Unix 4.2.8.0 64-Bit OS: False 64-Bit Process: False User Interactive: True Processor count: 4 Program data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.TypeInitializationException: System.TypeInitializationException: The type initializer for 'Emby.Sqlite.BaseSqliteRepository' threw an exception. ---> System.EntryPointNotFoundException: Unable to find an entry point named 'sqlite3_config' in shared library 'sqlite3'. at SQLitePCL.SQLite3Provider_sqlite3.NativeMethods.sqlite3_config_int(Int32 op, Int32 val) at SQLitePCL.SQLite3Provider_sqlite3.SQLitePCL.ISQLite3Provider.sqlite3_config(Int32 op, Int32 val) at SQLitePCL.raw.sqlite3_config(Int32 op, Int32 val) at Emby.Sqlite.BaseSqliteRepository..cctor() --- End of inner exception stack trace --- at Emby.Sqlite.BaseSqliteRepository..ctor(ILogger logger) at Emby.Server.Implementations.Data.SqliteUserRepository..ctor(ILogger logger, IServerApplicationPaths appPaths, IJsonSerializer jsonSerializer) at Emby.Server.Implementations.ApplicationHost.GetUserRepository() at Emby.Server.Implementations.ApplicationHost.RegisterResources(FfmpegConfiguration ffmpegInfo) at Emby.Server.Implementations.ApplicationHost.Init() at EmbyServer.Program.InitAppHost(CoreAppHost appHost, ILogger logger) at EmbyServer.Program.RunApplication(ServerApplicationPaths appPaths, ILogManager logManager, IEnvironmentInfo environmentInfo, StartupOptions options) at EmbyServer.Program.AfterMutexCreated(ServerApplicationPaths appPaths, IEnvironmentInfo environmentInfo, ILogger logger, StartupOptions options, ILogManager logManager) at EmbyServer.Program.Main(String[] args) Source: Emby.Sqlite TargetSite: Void .ctor(MediaBrowser.Model.Logging.ILogger) at Emby.Sqlite.BaseSqliteRepository..ctor(ILogger logger) at Emby.Server.Implementations.Data.SqliteUserRepository..ctor(ILogger logger, IServerApplicationPaths appPaths, IJsonSerializer jsonSerializer) at Emby.Server.Implementations.ApplicationHost.GetUserRepository() at Emby.Server.Implementations.ApplicationHost.RegisterResources(FfmpegConfiguration ffmpegInfo) at Emby.Server.Implementations.ApplicationHost.Init() at EmbyServer.Program.InitAppHost(CoreAppHost appHost, ILogger logger) at EmbyServer.Program.RunApplication(ServerApplicationPaths appPaths, ILogManager logManager, IEnvironmentInfo environmentInfo, StartupOptions options) at EmbyServer.Program.AfterMutexCreated(ServerApplicationPaths appPaths, IEnvironmentInfo environmentInfo, ILogger logger, StartupOptions options, ILogManager logManager) at EmbyServer.Program.Main(String[] args) InnerException: System.EntryPointNotFoundException: Unable to find an entry point named 'sqlite3_config' in shared library 'sqlite3'. Source: SQLitePCLRaw.provider.sqlite3 TargetSite: Int32 sqlite3_config_int(Int32, Int32) at SQLitePCL.SQLite3Provider_sqlite3.NativeMethods.sqlite3_config_int(Int32 op, Int32 val) at SQLitePCL.SQLite3Provider_sqlite3.SQLitePCL.ISQLite3Provider.sqlite3_config(Int32 op, Int32 val) at SQLitePCL.raw.sqlite3_config(Int32 op, Int32 val) at Emby.Sqlite.BaseSqliteRepository..cctor() UnhandledException System.TypeInitializationException: System.TypeInitializationException: The type initializer for 'Emby.Sqlite.BaseSqliteRepository' threw an exception. ---> System.EntryPointNotFoundException: Unable to find an entry point named 'sqlite3_config' in shared library 'sqlite3'. at SQLitePCL.SQLite3Provider_sqlite3.NativeMethods.sqlite3_config_int(Int32 op, Int32 val) at SQLitePCL.SQLite3Provider_sqlite3.SQLitePCL.ISQLite3Provider.sqlite3_config(Int32 op, Int32 val) at SQLitePCL.raw.sqlite3_config(Int32 op, Int32 val) at Emby.Sqlite.BaseSqliteRepository..cctor() --- End of inner exception stack trace --- at Emby.Sqlite.BaseSqliteRepository..ctor(ILogger logger) at Emby.Server.Implementations.Data.SqliteUserRepository..ctor(ILogger logger, IServerApplicationPaths appPaths, IJsonSerializer jsonSerializer) at Emby.Server.Implementations.ApplicationHost.GetUserRepository() at Emby.Server.Implementations.ApplicationHost.RegisterResources(FfmpegConfiguration ffmpegInfo) at Emby.Server.Implementations.ApplicationHost.Init() at EmbyServer.Program.InitAppHost(CoreAppHost appHost, ILogger logger) at EmbyServer.Program.RunApplication(ServerApplicationPaths appPaths, ILogManager logManager, IEnvironmentInfo environmentInfo, StartupOptions options) at EmbyServer.Program.AfterMutexCreated(ServerApplicationPaths appPaths, IEnvironmentInfo environmentInfo, ILogger logger, StartupOptions options, ILogManager logManager) at EmbyServer.Program.Main(String[] args) Source: Emby.Sqlite TargetSite: Void .ctor(MediaBrowser.Model.Logging.ILogger) at Emby.Sqlite.BaseSqliteRepository..ctor(ILogger logger) at Emby.Server.Implementations.Data.SqliteUserRepository..ctor(ILogger logger, IServerApplicationPaths appPaths, IJsonSerializer jsonSerializer) at Emby.Server.Implementations.ApplicationHost.GetUserRepository() at Emby.Server.Implementations.ApplicationHost.RegisterResources(FfmpegConfiguration ffmpegInfo) at Emby.Server.Implementations.ApplicationHost.Init() at EmbyServer.Program.InitAppHost(CoreAppHost appHost, ILogger logger) at EmbyServer.Program.RunApplication(ServerApplicationPaths appPaths, ILogManager logManager, IEnvironmentInfo environmentInfo, StartupOptions options) at EmbyServer.Program.AfterMutexCreated(ServerApplicationPaths appPaths, IEnvironmentInfo environmentInfo, ILogger logger, StartupOptions options, ILogManager logManager) at EmbyServer.Program.Main(String[] args) InnerException: System.EntryPointNotFoundException: Unable to find an entry point named 'sqlite3_config' in shared library 'sqlite3'. Source: SQLitePCLRaw.provider.sqlite3 TargetSite: Int32 sqlite3_config_int(Int32, Int32) at SQLitePCL.SQLite3Provider_sqlite3.NativeMethods.sqlite3_config_int(Int32 op, Int32 val) at SQLitePCL.SQLite3Provider_sqlite3.SQLitePCL.ISQLite3Provider.sqlite3_config(Int32 op, Int32 val) at SQLitePCL.raw.sqlite3_config(Int32 op, Int32 val) at Emby.Sqlite.BaseSqliteRepository..cctor()
Luke 42240 Posted November 26, 2018 Posted November 26, 2018 Ok thanks. The next beta build will have the libc change, so please try that. Thanks.
LocutusDeBorg 0 Posted November 28, 2018 Author Posted November 28, 2018 Good news! The latest build runs (with a couple of minor changes). I had to change the wrapper script ($APP_DIR/bin/emby-server) to first cd to the $APP_DIR/bin directory and then exec the system/EmbyServer from there. So the exec line looks like this: cd $APP_DIR/bin && exec ../system/EmbyServer \ -programdata $APP_DIR/programdata \ -ffdetect $APP_DIR/bin/ffdetect \ -ffmpeg $APP_DIR/bin/ffmpeg \ -ffprobe $APP_DIR/bin/ffprobe \ -defaultdirectory /share/CACHEDEV1_DATA \ -updatepackage 'emby-server-qnap_{version}_x86_64.qpkg' Without changing to the bin directory, none of the binaries work (including the ff* ones). The error message is: [/share/CACHEDEV1_DATA/.qpkg/EmbyServer] # bin/ffmpeg -sh: bin/ffmpeg: No such file or directory I also changed the system/EmbyServer.runtimeconfig.json as described in my previous post.
TheLizard 0 Posted November 28, 2018 Posted November 28, 2018 I tried the same thing, since I was getting "No such file or directory" for EmbyServer itself. I also had to set the System.Globalization.Invariant setting to true. But I still can't get it to start, I'm now getting: Info Main: Application path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll Cannot get required symbol EC_KEY_set_public_key_affine_coordinates from libssl Aborted libssl is libssl.so.1.0.0
alucryd 318 Posted November 28, 2018 Posted November 28, 2018 Good news! The latest build runs (with a couple of minor changes). I had to change the wrapper script ($APP_DIR/bin/emby-server) to first cd to the $APP_DIR/bin directory and then exec the system/EmbyServer from there. So the exec line looks like this: cd $APP_DIR/bin && exec ../system/EmbyServer \ -programdata $APP_DIR/programdata \ -ffdetect $APP_DIR/bin/ffdetect \ -ffmpeg $APP_DIR/bin/ffmpeg \ -ffprobe $APP_DIR/bin/ffprobe \ -defaultdirectory /share/CACHEDEV1_DATA \ -updatepackage 'emby-server-qnap_{version}_x86_64.qpkg' Without changing to the bin directory, none of the binaries work (including the ff* ones). The error message is: [/share/CACHEDEV1_DATA/.qpkg/EmbyServer] # bin/ffmpeg -sh: bin/ffmpeg: No such file or directory I also changed the system/EmbyServer.runtimeconfig.json as described in my previous post. OMG, all this time I thought the dynamic loader path was resolved relative to the binary, not to the current directory. Thank you so much for pointing this out! We will have new betas shortly which will take this into account (cding in the parent directory instead, changed the loader path to just lib/ld-blah.so). Also you won't need to disable globalization anymore, and libssl should work fine as well.
