chadsyf 0 Posted November 23, 2018 Posted November 23, 2018 ie: TV Shows, Movies, Recordings, Live TV, etc etc I just want a plain colored box, instead of these 4 striped images gathered from media within. Part of the issue is, it's duplicating a lot of stuff and grabbing images that are not very good looking... so I'd prefer to just have it as a plain colored "TV Shows" and "Movies". Every time I delete the image, it just eventually replaces it again and it looks awful. tia
Happy2Play 9806 Posted November 23, 2018 Posted November 23, 2018 Only way to stop the dynamic images is providing you own custom images.
Luke 42216 Posted November 23, 2018 Posted November 23, 2018 Hi there, instead of deleting it what you can do is customize it by supplying your own image of choice. Please let us know if this helps. Thanks !
chadsyf 0 Posted November 23, 2018 Author Posted November 23, 2018 (edited) I don't have an image that would fit exactly (not sure what the dimensions, etc are that would be required), or really, any kind of images that would be appropriate for all of the different categories. Is this something that could be eventually added as an option somewhere? Perhaps in the "manage library" advanced options [ ] checkbox for do not use dynamic images (default off, so it uses it like you want by default, but others could turn it off if desired)? Edit: i see it's 640x360 now in the options, but still, I don't have an appropriate image Edited November 23, 2018 by chadsyf
Solution Happy2Play 9806 Posted November 23, 2018 Solution Posted November 23, 2018 Have you browsed the community images uploaded in Community Contributions. https://emby.media/community/index.php?/forum/70-fan-art-videos/ 1
chadsyf 0 Posted November 23, 2018 Author Posted November 23, 2018 Ohhh perfect.... thanks!! Works and looks amazing
djhifi 56 Posted November 23, 2018 Posted November 23, 2018 (edited) Ohhh perfect.... thanks!! Works and looks amazing Hey, take a look at some of "mine" which I use for my libraries from time to time: Edited November 23, 2018 by djhifi
Luke 42216 Posted November 23, 2018 Posted November 23, 2018 What can we do to make this easier to discover?
Happy2Play 9806 Posted November 23, 2018 Posted November 23, 2018 Initially the OP just wanted a option to stop dynamic images and only display the default/colored placeholders
