ginjaninja 605 Posted April 19, 2014 Posted April 19, 2014 (edited) Version 3.0.5211.41935 the server places 'a.c.o.d' at 'c' in terms of sort order. The server places 'a.i' at 'I' in terms of sort order. Any reason why the server couldnt be configured to 'treat' leading 'a ' and leave alone leading 'a.' or indeed 'a{anything but space}' Which dont need special treatment. Sent from my GT-I9505 using Tapatalk Edited April 19, 2014 by ginjaninja
bigjohn 754 Posted April 19, 2014 Posted April 19, 2014 Since this is a problem with very limited scope, the best solution is probably just editing the sort order field for each one manually using the metadata editor.
ginjaninja 605 Posted April 19, 2014 Author Posted April 19, 2014 Since this is a problem with very limited scope, the best solution is probably just editing the sort order field for each one manually using the metadata editor. No doubt this is not a big issue and there is a workaround. But assuming the current logic is not achieving what it is setting out to achieve; to that extent and the extent to which the logic is improvable, it can be considered a bug? Sent from my GT-I9505 using Tapatalk
Solution ebr 16305 Posted April 19, 2014 Solution Posted April 19, 2014 Yeah, it's a bug. We should be looking for "a " specifically. 1
