FrostByte 5453 Posted November 26, 2018 Posted November 26, 2018 (edited) @@FrostByte what are you seeing? I'm seeing mpeg-2, h264, vc1, vp8, h265, and vp9 decoders automatically checked for VAAPI along with h264 VAAPI encoder automatically checked Edited November 26, 2018 by FrostByte
Luke 42241 Posted November 26, 2018 Posted November 26, 2018 Great. Can you test a few things and provide some transcode logs? Thanks !
FrostByte 5453 Posted November 26, 2018 Posted November 26, 2018 Ya, I'll try to force a transcode of the ones from that list which I know I have
FrostByte 5453 Posted November 26, 2018 Posted November 26, 2018 Client is Samsung 1.0.29. Both client and NAS are hardwired to same extender. HEVC 2160p forced transcoded to 1080p 10Mbps played smoothly https://pastebin.com/c3QSYgC5 AVC 1080p forced transcoded to 720p 4Mbps played smoothly https://pastebin.com/fAkfpDHt HEVC with internal PGS subs was choppy and looks like it may have reverted to software https://pastebin.com/aft453Th
solabc16 379 Posted November 26, 2018 Posted November 26, 2018 Many thanks @@FrostByte, we're heading in the right direction. Best - James
softworkz 5133 Posted November 27, 2018 Posted November 27, 2018 HEVC with internal PGS subs was choppy and looks like it may have reverted to software https://pastebin.com/aft453Th Should be fixed in the next version, thanks for testing! 1
Gohlas 14 Posted November 27, 2018 Posted November 27, 2018 Hei @@solabc16 Is this 3.6.0.71 still available? Cannot find it in my package center.
solabc16 379 Posted November 27, 2018 Posted November 27, 2018 Hello @@Gohlas What Synology model are you running? Best - James
solabc16 379 Posted November 27, 2018 Posted November 27, 2018 Hello @@Gohlas Yes, definitely available - if you've updated DSM recently, make sure the 'show beta versions' checkbox is still ticked. Let me know... Best - James
solabc16 379 Posted November 27, 2018 Posted November 27, 2018 (edited) Hello @@kyrios, @@FrostByte, All Mono (netframework) beta 3.6.0.72-1-beta, is now available. Let us know how you get on... Best - James Edited November 27, 2018 by solabc16 1
FrostByte 5453 Posted November 28, 2018 Posted November 28, 2018 (edited) I've loaded .72-1. Using the internal PGS sub was still unwatchable when I played the 4K movie Inferno. There are only 29 lines in the file, but the movie kept playing a few seconds then would display the spinner and then play another few seconds, then display the spinner again .etc, etc. This movie plays fine when using the external srt I created myself from the internal PGS file. Movie was direct playing per SFN with subtitle extraction on the fly set on server. Does it need to convert the video also when just extracting/converting the internal sub? I thought it may extract the subtitle, convert the sub to srt or something, then direct play without touching the video. https://pastebin.com/nsDwdraZ EDIT: the NAS transcodes 4K just fine when not dealing with internal subs. Edited November 28, 2018 by FrostByte
unr3al2 0 Posted November 28, 2018 Posted November 28, 2018 How to download the beta version for 918+?
FrostByte 5453 Posted November 28, 2018 Posted November 28, 2018 How to download the beta version for 918+? You have to PM solabc16 to get access and then he will send you back the instructions https://github.com/MediaBrowser/Wiki/wiki/Synology-:-Accessing-Beta-and-Development-Releases
