gmontem 6 Posted November 22, 2018 Posted November 22, 2018 I am using Emby Theater 2.8.1 on a Windows 10 machine and noticed some of the settings pages overlap one another, making configuration difficult to figure out if not impossible. I tried with a different Windows 10 system and got the same results. Not a bug: The Settings > Display looks fine Audio page MadVR Video Player Video When I get to one of these broken pages, I have to quit the app to get back to a useable state. The broken page will continue to draw on top of the home screen.
Luke 42242 Posted November 22, 2018 Posted November 22, 2018 Hi, this will be resolved if you install the latest version. Thanks !
gmontem 6 Posted November 22, 2018 Author Posted November 22, 2018 (edited) What is the build of the latest version? I thought I installed the latest version. Maybe the setup.exe doesn't upgrade an old version correctly. I just uninstalled my Emby Theater and will try again. Thanks. Edit: Looks like I need to uninstall the old one. I now have 3.0.5 running. Thanks! Edited November 22, 2018 by gmontem
