k0Lm. 32 Posted November 22, 2018 Posted November 22, 2018 Ok so here are 3 files; first file #TRANSCODING can only be played with transcoding. Second file #NOTTRANSCODING can be played without transcoding and #FFMPEG which is not telling much next to "TranscodeReasons=ContainerBitrateExceedsLimit" which is clearly a faulty return code. (subtitles are switched off in the app settings so that cant be the reason). On a side note; please don't update the samsung tv app from 1.0.44 to 1.0.45 because that will result in more transcoding; the 1.0.44 can play files with directplay which 1.0.45 can not do. #TRANSCODING: General Unique ID : 194738317320657314826771447735927829579 (0x92813C54864F325EA8FF31FF80A9F44B) Complete name : ~\video\series\Breaking Bad\Season 1\S01E01.mkv Format : Matroska Format version : Version 4 File size : 400 MiB Duration : 58 min 6 s Overall bit rate : 963 kb/s Movie name : E01 - Pilot Encoded date : UTC 2016-02-28 08:07:33 Writing application : mkvmerge v8.4.0 ('A better way to fly') 64bit Writing library : libebml v1.3.1 + libmatroska v1.4.2 Cover : Yes Attachments : cover.jpg Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 12 Ref Frames Format settings, CABAC : Yes Format settings, RefFrames : 12 frames Codec ID : V_MPEG4/ISO/AVC Duration : 58 min 6 s Nominal bit rate : 907 kb/s Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.041 Title : S01E01 Writing library : x264 core 148 r2597 e86f3a1 Encoding settings : cabac=1 / ref=12 / deblock=1:-2:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=907 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=30000 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00 Language : English Default : Yes Forced : No Audio ID : 2 Format : AAC LC SBR Format/Info : Advanced Audio Codec Low Complexity with Spectral Band Replication Commercial name : HE-AAC Format settings : Explicit Codec ID : A_AAC-2 Duration : 58 min 6 s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 23.438 FPS (2048 SPF) Compression mode : Lossy Delay relative to video : 31 ms Title : S01E01 Language : English Default : Yes Forced : No Text #1 ID : 3 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : English Default : No Forced : No Text #2 ID : 4 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : Indonesian Default : No Forced : No Menu 00:00:00.000 : en:01 00:04:07.080 : en:02 00:16:07.216 : en:03 00:31:41.149 : en:04 00:48:30.658 : en:05 00:57:12.262 : en:06 #NOTTRANSCODING General Unique ID : 194799718793237356355923000640038813992 (0x928D0FA810839D0A81F0147A0824C128) Complete name : ~\video\series\Breaking Bad\Season 2\S02E01.mkv Format : Matroska Format version : Version 4 File size : 350 MiB Duration : 47 min 15 s Overall bit rate : 1 036 kb/s Movie name : E02 Encoded date : UTC 2016-04-25 16:57:30 Writing application : mkvmerge v9.0.1 ('Obstacles') 64bit Writing library : libebml v1.3.3 + libmatroska v1.4.4 Cover : Yes Attachments : cover.jpg Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 8 Ref Frames Format settings, CABAC : Yes Format settings, RefFrames : 8 frames Codec ID : V_MPEG4/ISO/AVC Duration : 47 min 15 s Nominal bit rate : 982 kb/s Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.044 Title : S02E01 Writing library : x264 core 148 r2692 64f4e24 Encoding settings : cabac=1 / ref=8 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=982 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=37500 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00 Language : English Default : Yes Forced : No Audio ID : 2 Format : AAC LC SBR Format/Info : Advanced Audio Codec Low Complexity with Spectral Band Replication Commercial name : HE-AAC Format settings : Explicit Codec ID : A_AAC-2 Duration : 47 min 15 s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 23.438 FPS (2048 SPF) Compression mode : Lossy Delay relative to video : 31 ms Title : S02E01 Language : English Default : No Forced : No Text ID : 3 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : English Default : No Forced : No Menu 00:00:00.000 : :00:00:00.000 00:01:34.886 : :00:01:34.886 00:16:19.395 : :00:16:19.395 00:26:15.199 : :00:26:15.199 00:38:55.542 : :00:38:55.542 00:46:30.204 : :00:46:30.204 #FFMPEG 2018-11-22 13:23:32.274 Application version: 3.6.0.66 http://192.168.2.13:8096/emby/videos/16918/hls1/main/0.ts?DeviceId=TW96aWxsYS81LjAgKFNNQVJULVRWOyBMSU5VWDsgVGl6ZW4gMy4wKSBBcHBsZVdlYktpdC81MzguMSAoS0hUTUwsIGxpa2UgR2Vja28pIFZlcnNpb24vMy4wIFRWIFNhZmFyaS81MzguMXwxNTM3MTk3MjU4OTA4&MediaSourceId=8257a99e547f5d49b6887c6c523f3d29&VideoCodec=h264,h265,hevc&AudioCodec=ac3,eac3,aac,mp3,opus&VideoBitrate=139808000&AudioBitrate=192000&PlaySessionId=98156bdea8d14a4db1ad13f784e0982f&api_key=cbbc774c19df464b9a26f835b791d797&AudioStreamIndex=1&TranscodingMaxAudioChannels=6&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=False&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&TranscodeReasons=ContainerBitrateExceedsLimit&allowVideoStreamCopy=false {"Protocol":"File","Id":"8257a99e547f5d49b6887c6c523f3d29","Path":"/mnt/raid/video/series/Breaking Bad/Season 1/S01E01.mkv","Type":"Default","Container":"mkv","Size":419799035,"Name":"S01E01","IsRemote":false,"RunTimeTicks":34865381376,"ReadAtNativeFramerate":false,"DiscardCorruptPts":false,"FillWallClockDts":false,"IgnoreDts":false,"IgnoreIndex":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":true,"MediaStreams":[{"Codec":"h264","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1001/48000","Title":"S01E01","VideoRange":"SDR","DisplayTitle":"720P H264","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"BitRate":963245,"BitDepth":8,"RefFrames":1,"IsDefault":true,"IsForced":false,"Height":720,"Width":1280,"AverageFrameRate":23.9760246,"RealFrameRate":23.9760246,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":41,"IsAnamorphic":false},{"Codec":"aac","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"S01E01","DisplayTitle":"Eng AAC stereo Default","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Profile":"HE-AAC","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"subrip","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Eng","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":2,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Level":0},{"Codec":"subrip","Language":"ind","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Ind","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":3,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Level":0},{"Codec":"mjpeg","ColorSpace":"bt470bg","TimeBase":"1/90000","CodecTimeBase":"0/1","IsInterlaced":false,"BitDepth":8,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":118,"Width":217,"RealFrameRate":90000,"Profile":"194","Type":"EmbeddedImage","AspectRatio":"1.85:1","Index":4,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuvj444p","Level":-99,"IsAnamorphic":false},{"Codec":"srt","Language":"dut","DisplayTitle":"Dut","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":5,"IsExternal":true,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Path":"/mnt/raid/video/series/Breaking Bad/Season 1/S01E01.nl.srt"}],"Formats":[],"Bitrate":963245,"RequiredHttpHeaders":{}} User policy for Lok: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True Affected codecs: >>>>>> libx264 Software Encoder Color Formats: YUV420P, YUVJ420P, YUV422P, YUVJ422P, YUV444P, YUVJ444P, NV12, NV16, NV21, YUV420P10LE, YUV422P10LE, YUV444P10LE, NV20LE Profiles: Baseline Profile (Level 6.2), Main Profile (Level 6.2), High Profile (Level 6.2), High 10 Profile (Level 6.2), High 4:2:2 Profile (Level 6.2), High 4:4:4 Predictive Profile (Level 6.2) >>>>>> FindVideoEncoder - Media: h264, UseHardwareCodecs: True, Mode: 1 Info FindVideoEncoder - Checking: 'libx264 Software Encoder' (Priority: 0) Info Encoder supports input stream Info FindVideoEncoder - Check successful - selecting 'libx264 Software Encoder' >>>>>> FindVideoDecoder - MediaType: h264, Mode: 1 Info FindVideoDecoder - Checking: 'Automatic software decoder' (Priority: 0) Info FindVideoDecoder - Check successful - selecting 'Automatic software decoder' >>>>>> FindVideoDecoder - MediaType: h264, Mode: 1 Info FindVideoDecoder - Checking: 'Automatic software decoder' (Priority: 0) Info FindVideoDecoder - Check successful - selecting 'Automatic software decoder' >>>>>> FindVideoEncoder - Media: h264, UseHardwareCodecs: True, Mode: 1 Info FindVideoEncoder - Checking: 'libx264 Software Encoder' (Priority: 0) Info Encoder supports input stream Info FindVideoEncoder - Check successful - selecting 'libx264 Software Encoder' >>>>>> FindVideoDecoder - MediaType: h264, Mode: 1 Info FindVideoDecoder - Checking: 'Automatic software decoder' (Priority: 0) Info FindVideoDecoder - Check successful - selecting 'Automatic software decoder' >>>>>> FindVideoDecoder - MediaType: h264, Mode: 1 Info FindVideoDecoder - Checking: 'Automatic software decoder' (Priority: 0) Info FindVideoDecoder - Check successful - selecting 'Automatic software decoder' /opt/emby-server/bin/ffmpeg -f matroska -i file:"/mnt/raid/video/series/Breaking Bad/Season 1/S01E01.mkv" -threads 0 -map 0:0 -map 0:1 -map -0:s -c:v:0 libx264 -pix_fmt yuv420p -maxrate 2889735 -bufsize 5779470 -profile high -level 4.1 -crf 23 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:if(isnan(prev_forced_t),eq(t,t),gte(t,prev_forced_t+3))" -copyts -vsync -1 -codec:a:0 copy -f segment -max_delay 5000000 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 0 -segment_list "/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d.m3u8" -y "/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d%d.ts" ffmpeg version 4.0.2-emby_2018_11_18 Copyright (c) 2000-2018 the FFmpeg developers built with gcc 6.3.0 (crosstool-NG crosstool-ng-1.23.0) configuration: --cc=x86_64-pc-linux-gnu-gcc --arch=x86_64 --prefix=/home/embybuilder/Buildbot/x64/ffmpeg-x64/staging --pkg-config=pkg-config --disable-doc --disable-ffplay --disable-vdpau --disable-xlib --enable-fontconfig --enable-gnutls --enable-gpl --enable-iconv --enable-libass --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libwebp --enable-libx264 --enable-libzvbi --enable-version3 --enable-libsmbclient --enable-cuda --enable-cuvid --enable-nvenc --enable-vaapi --enable-decoder=h264_cuvid --enable-decoder=hevc_cuvid --enable-decoder=mjpeg_cuvid --enable-decoder=mpeg1_cuvid --enable-decoder=mpeg2_cuvid --enable-decoder=mpeg4_cuvid --enable-decoder=vc1_cuvid --enable-decoder=vp8_cuvid --enable-decoder=vp9_cuvid --enable-encoder=h264_nvenc --enable-encoder=h264_vaapi --enable-encoder=hevc_nvenc --enable-encoder=hevc_vaapi --enable-encoder=mjpeg_vaapi --enable-cross-compile --cross-prefix=x86_64-pc-linux-gnu- --extra-libs='-ldl -lexpat -lfreetype -lfribidi -lfontconfig -liconv -lpng -luuid -lz -lvorbis -logg -lnettle -lhogweed -lgmp -laddns-samba4 -lasn1util-samba4 -lauthkrb5-samba4 -lCHARSET3-samba4 -lcliauth-samba4 -lcli-cldap-samba4 -lcli-ldap-common-samba4 -lcli-nbt-samba4 -lcli-smb-common-samba4 -lcom_err -lcommon-auth-samba4 -ldbwrap-samba4 -ldcerpc-binding -ldcerpc-samba-samba4 -lflag-mapping-samba4 -lgenrand-samba4 -lgensec-samba4 -lgse-samba4 -lgssapi_krb5 -llibcli-lsa3-samba4 -llibsmb-samba4 -linterfaces-samba4 -liov-buf-samba4 -lk5crypto -lkrb5 -lkrb5samba-samba4 -lkrb5support -lldb -lldbsamba-samba4 -lmessages-dgm-samba4 -lmessages-util-samba4 -lmsghdr-samba4 -lmsrpc3-samba4 -lndr -lndr-krb5pac -lndr-nbt -lndr-samba-samba4 -lndr-standard -lreplace-samba4 -lsamba-cluster-support-samba4 -lsamba-credentials -lsamba-debug-samba4 -lsamba-errors -lsamba-hostconfig -lsamba-modules-samba4 -lsamba-security-samba4 -lsamba-sockets-samba4 -lsamba-util -lsamba3-util-samba4 -lsamdb -lsamdb-common-samba4 -lsecrets3-samba4 -lserver-id-db-samba4 -lserver-role-samba4 -lsmbconf -lsmbd-shim-samba4 -lsmb-transport-samba4 -lsocket-blocking-samba4 -lsys-rw-samba4 -ltalloc -ltalloc-report-samba4 -ltdb -ltdb-wrap-samba4 -ltevent -ltevent-util -ltime-basic-samba4 -lutil-cmdline-samba4 -lutil-reg-samba4 -lutil-setid-samba4 -lutil-tdb-samba4 -lwbclient -lwinbind-client-samba4 -ldrm' --target-os=linux --enable-shared --disable-static libavutil 56. 14.100 / 56. 14.100 libavcodec 58. 18.100 / 58. 18.100 libavformat 58. 12.100 / 58. 12.100 libavdevice 58. 3.100 / 58. 3.100 libavfilter 7. 16.100 / 7. 16.100 libswscale 5. 1.100 / 5. 1.100 libswresample 3. 1.100 / 3. 1.100 libpostproc 55. 1.100 / 55. 1.100 Input #0, matroska,webm, from 'file:/mnt/raid/video/series/Breaking Bad/Season 1/S01E01.mkv': Metadata: title : E01 - Pilot encoder : libebml v1.3.1 + libmatroska v1.4.2 creation_time : 2016-02-28T08:07:33.000000Z Duration: 00:58:06.54, start: 0.000000, bitrate: 963 kb/s Chapter #0:0: start 0.000000, end 247.080000 Metadata: title : 01 Chapter #0:1: start 247.080000, end 967.216000 Metadata: title : 02 Chapter #0:2: start 967.216000, end 1901.149000 Metadata: title : 03 Chapter #0:3: start 1901.149000, end 2910.658000 Metadata: title : 04 Chapter #0:4: start 2910.658000, end 3432.262000 Metadata: title : 05 Chapter #0:5: start 3432.262000, end 3486.538000 Metadata: title : 06 Stream #0:0(eng): Video: h264 (High), yuv420p(progressive), 1280x720, SAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default) Metadata: title : S01E01 BPS : 906701 BPS-eng : 906701 DURATION : 00:58:06.483000000 DURATION-eng : 00:58:06.483000000 NUMBER_OF_FRAMES: 83592 NUMBER_OF_FRAMES-eng: 83592 NUMBER_OF_BYTES : 395150089 NUMBER_OF_BYTES-eng: 395150089 _STATISTICS_WRITING_APP: mkvmerge v8.4.0 ('A better way to fly') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v8.4.0 ('A better way to fly') 64bit _STATISTICS_WRITING_DATE_UTC: 2016-02-28 08:07:33 _STATISTICS_WRITING_DATE_UTC-eng: 2016-02-28 08:07:33 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:1(eng): Audio: aac (HE-AAC), 48000 Hz, stereo, fltp (default) Metadata: title : S01E01 BPS : 54466 BPS-eng : 54466 DURATION : 00:58:06.507000000 DURATION-eng : 00:58:06.507000000 NUMBER_OF_FRAMES: 81715 NUMBER_OF_FRAMES-eng: 81715 NUMBER_OF_BYTES : 23737029 NUMBER_OF_BYTES-eng: 23737029 _STATISTICS_WRITING_APP: mkvmerge v8.4.0 ('A better way to fly') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v8.4.0 ('A better way to fly') 64bit _STATISTICS_WRITING_DATE_UTC: 2016-02-28 08:07:33 _STATISTICS_WRITING_DATE_UTC-eng: 2016-02-28 08:07:33 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:2(eng): Subtitle: subrip Metadata: BPS : 51 BPS-eng : 51 DURATION : 00:56:48.988000000 DURATION-eng : 00:56:48.988000000 NUMBER_OF_FRAMES: 771 NUMBER_OF_FRAMES-eng: 771 NUMBER_OF_BYTES : 21844 NUMBER_OF_BYTES-eng: 21844 _STATISTICS_WRITING_APP: mkvmerge v8.4.0 ('A better way to fly') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v8.4.0 ('A better way to fly') 64bit _STATISTICS_WRITING_DATE_UTC: 2016-02-28 08:07:33 _STATISTICS_WRITING_DATE_UTC-eng: 2016-02-28 08:07:33 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:3(ind): Subtitle: subrip Metadata: BPS : 43 BPS-eng : 43 DURATION : 00:56:23.814000000 DURATION-eng : 00:56:23.814000000 NUMBER_OF_FRAMES: 589 NUMBER_OF_FRAMES-eng: 589 NUMBER_OF_BYTES : 18549 NUMBER_OF_BYTES-eng: 18549 _STATISTICS_WRITING_APP: mkvmerge v8.4.0 ('A better way to fly') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v8.4.0 ('A better way to fly') 64bit _STATISTICS_WRITING_DATE_UTC: 2016-02-28 08:07:33 _STATISTICS_WRITING_DATE_UTC-eng: 2016-02-28 08:07:33 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:4: Video: mjpeg, yuvj444p(pc, bt470bg/unknown/unknown), 217x118, 90k tbr, 90k tbn, 90k tbc Metadata: filename : cover.jpg mimetype : image/jpeg Please use -profile:a or -profile:v, -profile is ambiguous Stream mapping: Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (copy) Press [q] to stop, [?] for help [libx264 @ 0x1daeac0] using SAR=1/1 [libx264 @ 0x1daeac0] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 [libx264 @ 0x1daeac0] profile Main, level 4.1 [libx264 @ 0x1daeac0] 264 - core 152 r2854 e9a5903 - H.264/MPEG-4 AVC codec - Copyleft 2003-2017 - http://www.videolan.org/x264.html - options: cabac=1 ref=3 deblock=1:0:0 analyse=0x1:0 me=dia subme=0 psy=1 psy_rd=1.00:0.00 mixed_ref=1 me_range=4 chroma_me=0 trellis=1 8x8dct=0 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=6 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=23 scenecut=40 intra_refresh=0 rc_lookahead=10 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=2889 vbv_bufsize=5779 crf_max=0.0 nal_hrd=none filler=0 ip_ratio=1.40 aq=1:1.00 [segment @ 0x1dc7d80] Opening '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d0.ts' for writing Output #0, segment, to '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d%d.ts': Metadata: encoder : Lavf58.12.100 Stream #0:0: Video: h264 (libx264), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], q=-1--1, 23.98 fps, 90k tbn, 23.98 tbc (default) Metadata: encoder : Lavc58.18.100 libx264 Side data: cpb: bitrate max/min/avg: 2889000/0/0 buffer size: 5779000 vbv_delay: -1 Stream #0:1: Audio: aac (HE-AAC), 48000 Hz, stereo, fltp (default) frame= 90 fps=0.0 q=28.0 size=N/A time=00:00:04.08 bitrate=N/A speed=8.12x [segment @ 0x1dc7d80] Opening '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d.m3u8.tmp' for writing [segment @ 0x1dc7d80] Opening '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d1.ts' for writing frame= 161 fps=160 q=28.0 size=N/A time=00:00:07.02 bitrate=N/A speed=6.99x [segment @ 0x1dc7d80] Opening '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d.m3u8.tmp' for writing [segment @ 0x1dc7d80] Opening '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d2.ts' for writing frame= 232 fps=154 q=25.0 size=N/A time=00:00:10.09 bitrate=N/A speed=6.69x [segment @ 0x1dc7d80] Opening '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d.m3u8.tmp' for writing [segment @ 0x1dc7d80] Opening '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d3.ts' for writing frame= 301 fps=150 q=28.0 size=N/A time=00:00:12.78 bitrate=N/A speed=6.35x [segment @ 0x1dc7d80] Opening '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d.m3u8.tmp' for writing [segment @ 0x1dc7d80] Opening '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d4.ts' for writing frame= 378 fps=150 q=28.0 size=N/A time=00:00:16.07 bitrate=N/A speed=6.39x [segment @ 0x1dc7d80] Opening '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d.m3u8.tmp' for writing [segment @ 0x1dc7d80] Opening '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d5.ts' for writing frame= 448 fps=149 q=25.0 size=N/A time=00:00:19.14 bitrate=N/A speed=6.35x [segment @ 0x1dc7d80] Opening '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d.m3u8.tmp' for writing [segment @ 0x1dc7d80] Opening '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d6.ts' for writing frame= 493 fps=140 q=28.0 size=N/A time=00:00:20.76 bitrate=N/A speed= 5.9x [segment @ 0x1dc7d80] Opening '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d.m3u8.tmp' for writing [segment @ 0x1dc7d80] Opening '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d7.ts' for writing frame= 543 fps=135 q=28.0 size=N/A time=00:00:22.85 bitrate=N/A speed=5.67x frame= 593 fps=130 q=29.0 size=N/A time=00:00:25.24 bitrate=N/A speed=5.55x [segment @ 0x1dc7d80] Opening '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d.m3u8.tmp' for writing [segment @ 0x1dc7d80] Opening '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d8.ts' for writing frame= 636 fps=126 q=28.0 size=N/A time=00:00:26.99 bitrate=N/A speed=5.35x [segment @ 0x1dc7d80] Opening '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d.m3u8.tmp' for writing [segment @ 0x1dc7d80] Opening '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d9.ts' for writing frame= 683 fps=123 q=25.0 size=N/A time=00:00:28.83 bitrate=N/A speed= 5.2x frame= 737 fps=122 q=28.0 size=N/A time=00:00:31.13 bitrate=N/A speed=5.15x [segment @ 0x1dc7d80] Opening '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d.m3u8.tmp' for writing [segment @ 0x1dc7d80] Opening '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d10.ts' for writing frame= 786 fps=120 q=28.0 size=N/A time=00:00:33.18 bitrate=N/A speed=5.06x [segment @ 0x1dc7d80] Opening '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d.m3u8.tmp' for writing [segment @ 0x1dc7d80] Opening '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d11.ts' for writing frame= 832 fps=118 q=28.0 size=N/A time=00:00:35.23 bitrate=N/A speed=4.99x [segment @ 0x1dc7d80] Opening '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d.m3u8.tmp' for writing [segment @ 0x1dc7d80] Opening '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d12.ts' for writing frame= 900 fps=119 q=28.0 size=N/A time=00:00:37.96 bitrate=N/A speed=5.02x [segment @ 0x1dc7d80] Opening '/mnt/raid/encoding/transcoding-temp/2a480124fd8eea8e15d0b2d5e26cda5d.m3u8.tmp' for writing frame= 907 fps=115 q=-1.0 Lsize=N/A time=00:00:38.30 bitrate=N/A speed=4.88x video:7345kB audio:251kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown [libx264 @ 0x1daeac0] frame I:23 Avg QP:17.48 size: 63322 [libx264 @ 0x1daeac0] frame P:273 Avg QP:21.14 size: 15477 [libx264 @ 0x1daeac0] frame B:611 Avg QP:23.74 size: 3010 [libx264 @ 0x1daeac0] consecutive B-frames: 6.3% 9.0% 7.9% 76.7% [libx264 @ 0x1daeac0] mb I I16..4: 37.8% 0.0% 62.2% [libx264 @ 0x1daeac0] mb P I16..4: 16.4% 0.0% 0.0% P16..4: 49.1% 0.0% 0.0% 0.0% 0.0% skip:34.5% [libx264 @ 0x1daeac0] mb B I16..4: 1.6% 0.0% 0.0% B16..8: 15.7% 0.0% 0.0% direct: 4.8% skip:77.9% L0:43.8% L1:43.4% BI:12.8% [libx264 @ 0x1daeac0] coded y,uvDC,uvAC intra: 39.1% 50.7% 11.8% inter: 10.3% 11.1% 0.1% [libx264 @ 0x1daeac0] i16 v,h,dc,p: 36% 32% 19% 13% [libx264 @ 0x1daeac0] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 21% 21% 14% 8% 8% 7% 8% 6% 8% [libx264 @ 0x1daeac0] i8c dc,h,v,p: 41% 29% 22% 9% [libx264 @ 0x1daeac0] Weighted P-Frames: Y:9.5% UV:3.3% [libx264 @ 0x1daeac0] ref P L0: 73.7% 0.0% 19.1% 6.9% 0.2% [libx264 @ 0x1daeac0] ref B L0: 84.7% 12.0% 3.3% [libx264 @ 0x1daeac0] ref B L1: 95.8% 4.2% [libx264 @ 0x1daeac0] kb/s:1590.41
Luke 42241 Posted November 22, 2018 Posted November 22, 2018 We need to improve the display reasoning when this happens, but the third one tried to direct play, then automatically switched to transcoding when the tizen video player reported an error with it. So no faulty code we can conclude. Thanks.
k0Lm. 32 Posted November 22, 2018 Author Posted November 22, 2018 Thanks for the reply. The third one is an ffmpeg log from the first (#transcoding) video file. Which is encoded the exact same way as the second video file, and the same source is used, as you can see, the details are identical. So there is no way to find out why its transcoding?
Luke 42241 Posted November 22, 2018 Posted November 22, 2018 @@SamES will know more but usually the error codes we get are vague such as media decoding failure or network error, etc. 1
SamES 1084 Posted November 22, 2018 Posted November 22, 2018 In the first sample that transcodes, I’m sure it’s the number of reference frames that’s the issue. I think for profile 4.1 @ 720p, 9 Ref Frames is the maximum. This would likely just cause a generic ‘codec’ error on the player and fall back to transcoding after trying to DirectPlay 2
Solution FrostByte 5453 Posted November 22, 2018 Solution Posted November 22, 2018 Correct. Max ref frames = 12288 * 1024 / ( width * height * 1.5) for x264 L4.1 . If there are black bars you can crop then you can get away with a few more. Samsung TVs have always been strict to adhering to the RF standard. 2
k0Lm. 32 Posted November 23, 2018 Author Posted November 23, 2018 Hmm thank you all for the detailed explanation! I can work with this and really appreciate it. 1
