unhooked 17 Posted November 22, 2018 Posted November 22, 2018 Ok so I slapped together something after taking notes here and adding to my existing cruft to remove commercials and attempt to make tv more roku friendly. The problem is, trying to just re-container .ts leaves me with horrible audio desync. Everything else works as expected, just ffmpeg -c copy is ugly. http://unhooked.net/tv/afterplex handbrake transcodes just fine, but I was hoping for fast which this isn't. suggestions to make ffmpeg play nice, or alternatives welcome. 12-Stable, comcut github, everythign else pkg.
Luke 42239 Posted November 22, 2018 Posted November 22, 2018 Hi, have you checked out our media conversion feature?
unhooked 17 Posted November 22, 2018 Author Posted November 22, 2018 Hi, have you checked out our media conversion feature? Can it be triggered to remove commercials and then re-container the resulting output?
Luke 42239 Posted November 22, 2018 Posted November 22, 2018 commercials no, but that is planned for the future. yes it can convert to mp4/mkv.
unhooked 17 Posted November 22, 2018 Author Posted November 22, 2018 commercials no, but that is planned for the future. yes it can convert to mp4/mkv. Got that covered, I was mainly looking for the magic flags to re-container without transcoding for stuff that's not going to stick around.
CBers 7554 Posted November 22, 2018 Posted November 22, 2018 @@unhooked I know this is a Powershell post, but the FFMPEG commands should be the same. https://emby.media/community/index.php?/topic/62567-post-processing-script-working-example-powershell @@PenkethBoy may have tweaked some of the parameters since the his original post.
