Thuzad 50 Posted November 21, 2018 Posted November 21, 2018 Hello, I noticed that the filters have changed would it be possible to put a multiple selection as before. For example for the year of release of the film could have to choose several. We see on the screen that one part to a single selection and the other a multiple selection. Maybe there is a reason for this change? Best regards 4
Thuzad 50 Posted January 22, 2019 Author Posted January 22, 2019 Any news ? I like sorting my movies in a slice of year
Thuzad 50 Posted March 18, 2019 Author Posted March 18, 2019 Hello, it's only me that this regression annoys? In 3.5 year search was very good and it was changed after.
Luke 42246 Posted March 18, 2019 Posted March 18, 2019 We'll have multi select in an upcoming update. Thanks.
Thuzad 50 Posted July 11, 2019 Author Posted July 11, 2019 Hello, I saw that you have changed the filters a little by adding new ones. But the selection feature with several options has not changed. Do you have an idea when will this function come back?
anthony_m 8 Posted May 31, 2020 Posted May 31, 2020 Bump, this would be so important and much better than adding more preconfigured filters like filtering by decade.
ebr 16339 Posted May 31, 2020 Posted May 31, 2020 Just FYI - you can mult-select filters in the Android TV app.
anthony_m 8 Posted June 1, 2020 Posted June 1, 2020 Thanks,unfortunately I do not own an Android TV. It is quite strange that on a device where we can select and deselect the filters much quicker we do not have this but we have it on the rather clumsy Android TV where we operate the interface with a remote control. Can we expect to have it soon in the iOS and android app?
Luke 42246 Posted June 1, 2020 Posted June 1, 2020 We plan to add multi-select filters to the iOS and android apps in future updates. thanks for the feedback.
anthony_m 8 Posted June 1, 2020 Posted June 1, 2020 We plan to add multi-select filters to the iOS and android apps in future updates. thanks for the feedback. Excellent, really looking forward to that!
Thuzad 50 Posted October 1, 2020 Author Posted October 1, 2020 On 6/1/2020 at 3:49 AM, Luke said: We plan to add multi-select filters to the iOS and android apps in future updates. thanks for the feedback. The web app is also planned?
Luke 42246 Posted October 1, 2020 Posted October 1, 2020 2 minutes ago, Floflobel said: The web app is also planned? Yes. 1
Luke 42246 Posted January 23, 2021 Posted January 23, 2021 You'll be able to multi-select filter in the upcoming Emby Server 4.6 release. Thanks. 1
anthony_m 8 Posted January 23, 2021 Posted January 23, 2021 Excellent! When do you expect 4.6.to become available?
Thuzad 50 Posted January 23, 2021 Author Posted January 23, 2021 Really good news ! Thank for your work !
Thuzad 50 Posted February 8, 2021 Author Posted February 8, 2021 I change the tag from "In progress" to "Completed".
ebr 16339 Posted February 8, 2021 Posted February 8, 2021 Since this is only in beta it is still in-progress from our standpoint. Thanks. 1
