maximus1 2 Posted April 18, 2014 Posted April 18, 2014 when i try to update the database movies with ä (ae), ü (ue) or ö (oe) are ignored. 2014-04-18 16:44:14.7510 Warn - BaseItem: Unable to find linked item at path \\+++\+++\Die Addams Family in verr�ckter Tradition\Die Addams Family in verr�ckter Tradition.avi is it possible to convert these letters bevore searching in the net by the server?
Luke 42176 Posted April 18, 2014 Posted April 18, 2014 that's not actually an issue of searching the internet. that means you have a shortcut file (lnk) pointing to that file and we're unable to find it.
maximus1 2 Posted April 18, 2014 Author Posted April 18, 2014 (edited) what exactly do you mean? i´ve not found any information about boxset shortcuts. the files which are not processed are in the same type of organisation like the other files who are prcessed. Edited April 18, 2014 by maximus1
Luke 42176 Posted April 18, 2014 Posted April 18, 2014 ok if you're not using those as boxset shortcuts, then the message doesn't mean anything. in which case we need to start over with a detailed description of the problem, full logs, screenshots, etc. thanks.
maximus1 2 Posted April 18, 2014 Author Posted April 18, 2014 ok. i´ll do this in the next days. i´m actualy not at home. thanks so far.
maximus1 2 Posted April 19, 2014 Author Posted April 19, 2014 all the files are on their places and can acessed via network and eplorer.
Luke 42176 Posted April 19, 2014 Posted April 19, 2014 right but ifyou're intending to use them as boxset shortcuts they do need to follow the conventions listed in the library wiki.
