fernandolr0 0 Posted November 21, 2018 Posted November 21, 2018 (edited) Hi! Sorry my bad english, i'm from Argentina. I'm here bothering because i have some problems with emby (i'm New). It's running in the last lubuntu (18.10). MKV Files just run fine, but mp4 files don't (Circle keeps spining). I attach example logs (all looks similar) Thanks, and again sorry for bothering and the language. PD: I installed via apt-get ffmpeg, and some smb/cif utils. embylog.txt transcodelog1.txt Edited November 21, 2018 by fernandolr0
fernandolr0 0 Posted November 21, 2018 Author Posted November 21, 2018 What CPU architecture? x64 and 4gb of RAM Thanks
fernandolr0 0 Posted November 21, 2018 Author Posted November 21, 2018 Is this in a VM? No. It's a PC.
fernandolr0 0 Posted November 21, 2018 Author Posted November 21, 2018 It's a old PC that i have and i installed last night to test emby. Athlon II 160u
Luke 42246 Posted November 21, 2018 Posted November 21, 2018 It's hard to say if there's a problem with the old CPU or something related to lubuntu. Can you try installing the beta package to see if that is any different? Thanks.
fernandolr0 0 Posted November 21, 2018 Author Posted November 21, 2018 It's hard to say if there's a problem with the old CPU or something related to lubuntu. Can you try installing the beta package to see if that is any different? Thanks. Sure tomorrow i will do that. It will have "better performance" with freebsd ?
Luke 42246 Posted November 21, 2018 Posted November 21, 2018 You could give freebsd a shot as well. it's just hard to predict due to the older cpu. thanks.
fernandolr0 0 Posted November 21, 2018 Author Posted November 21, 2018 You could give freebsd a shot as well. it's just hard to predict due to the older cpu. thanks. To install the beta, i have to uninstall the actual version or i can just install it ?
