rliepins 9 Posted November 20, 2018 Posted November 20, 2018 WMC has a nice way of displaying information on recordings including original air date, date recorded, run time, etc. Is there a way of displaying Emby recordings information like that? Also, is there a way to enter Recordings into a blend of both Movies and Series, sort of like how WMC behaves? You might have seen the pattern here - I'm trying to ease the transition from WMC to Emby for other family members without having to explain all the changes and everything a bunch of times between the old and the new. Thanks
rliepins 9 Posted November 20, 2018 Author Posted November 20, 2018 Also, I'm not quite sure of the original content type of the Recordings folder, but it is currently mixed content. Would creating a new library to the same DVR location and setting it to TV shows content type mess anything up with regard to the movies recorded?
Luke 42244 Posted November 20, 2018 Posted November 20, 2018 Hi, can you show screenshots to demonstrate what you're asking for? thanks.
rliepins 9 Posted November 21, 2018 Author Posted November 21, 2018 Here is an example of a WMC recorded TV episode. Note the information, including the original air date...
Luke 42244 Posted November 21, 2018 Posted November 21, 2018 We have both of those dates as well, we just do them differently. The date on the third line is the air date. Then we have the added text at the bottom to indicate when you added it to your library.
