makarai 109 Posted February 28, 2019 Posted February 28, 2019 (edited) @stuardsjg Firstly. The command ought to fix the bug introduced with the update of freenas U2 of not having a default vnet set up. You can read all about it here https://redmine.ixsystems.com/issues/75648 . One workaround is when you have existing jails that wont start the command i posted the other workaround is click ADVANCED PLUGIN INSTALLATION in the installation screen and select “auto” for the VNET option or the command after you installed a jail. Secondly, the jls function is depreciated and the warden jail system will disappear soon. iocage to the rescue. I suppose you dont have any jails running. So lets start with a manual installation. follow this Thridly, the plugin route is still not possible with emby as the plugin fetch from freenas still installs the 3.5.X which is borked. It'll update at some point. Create an empty jail Dhcp or static -> use GUI and enter jail shell if it works great (use dhcp) #enter the jail shell pkg install mono libass fontconfig freetype2 fribidi gnutls iconv opus samba48 sqlite3 libtheora libva libvorbis webp libx264 libzvbi libraw pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/4.0.2.0/emby-server-freebsd_4.0.2.0_amd64.txz sysrc -f /etc/rc.conf emby_server_enable="YES" service emby-server start 2>/dev/null restart jail Edited February 28, 2019 by makarai
sproon 0 Posted August 1, 2019 Posted August 1, 2019 (edited) I posted this on another forum. Its the easiest solution to get the most updated emby server and works when updating to a new version. If this is still a problem, I noticed an easy fix for FreeNAS users. My issues happen when updating using the following commands from emby.media: pkg install mono libass fontconfig freetype2 fribidi gnutls iconv opus samba48 sqlite3 libtheora libva libvpx libvorbis webp libx264 libzvbi libraw ImageMagick6 pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/4.3.0.0/emby-server-freebsd11_4.3.0.0_amd64.txz After installing the new version, ffmpeg can't find several shared libraries that are actually included in the emby server package. You can check if something is missing in the iocage command line: ldd /usr/local/lib/emby-server/bin/ffmpeg All I did was copy all the libraries from the emby server package to the root directory and ran the above command to ensure ffmpeg had everything it needed cp /usr/local/lib/emby-server/lib/* /usr/local/lib/ After that, all content plays! Hope this helps! Edited August 1, 2019 by sproon
Luke 42239 Posted September 30, 2019 Posted September 30, 2019 For non-beta users who wish to run the stable release, the suggested approach is installing the IOCage plugin:
