natsu 4 Posted November 19, 2018 Posted November 19, 2018 Hi, Checked that the Snapdragon 410 have 720p H.264 decoding, my friend use Samsung Galaxy J5 2016 to check the transconding, but the mediacodec isn't response, compared to my MT6753 is different, would anyone help this? Thanks! Galaxy_J5_720p_transcoding.txt Galaxy_J5_1080p_transcoding.txt Galaxy_J5_Emby_Server.txt
natsu 4 Posted November 19, 2018 Author Posted November 19, 2018 Found the Samsung Galaxy J5 2016 is 32bit only, not 64bit OS, oh my god, so all transcoding process is affected?
Solution softworkz 5133 Posted November 20, 2018 Solution Posted November 20, 2018 No need to worry, we are supporting 32bit OS as well. (the only thing we don't support is running Emby Server as 32bit on a 64bit Android OS) There seems to be a problem with the bitrates being set for the Qualcomm encoder. Could you please try with lower bitrates? E.g. in the web client > playback settings > video quality: Try lower bitrate settings Thank you. 1
natsu 4 Posted November 21, 2018 Author Posted November 21, 2018 Hi Softworkz, I've checked that the lower bitrate didn't solve this, and I've checked that same behavior on my HTC desire 820 which is Snapdrangon 615, thanks!
natsu 4 Posted November 23, 2018 Author Posted November 23, 2018 After Updated to 3.6.0.68, My HTC Desire 820 has the same problem, but the root cause is on the specific VIdeo file from the following URL: http://distribution.bbb3d.renderfarming.net/video/mp4/bbb_sunflower_1080p_30fps_normal.mp4 But when I use other video file under 720p, found the transcoding process is workable on MediaCodec, but the Snapdragon 615 should support 1080p of H264... For Samsung J5 2016 with Snapdragon 410, I've use another Android Phone with Snapdragon 410 (ASUS Zenfone 2 Laser 5") with no problem for the same 720p H264 video, after checked some information, I think that the Samsung ROM with knox has problem on some program running background...
