perry59 7 Posted November 19, 2018 Posted November 19, 2018 up until recently I always used emby on my computer via the chrome app. I got a roku and downloaded the emby app to it and it plays ok, but many features are missing. For one thing I cant select subtitles or audio tracks. is this simply not do able? I'd like the roku interface to work just like the chrome interface. If I cant even select subtitles then the roku app is pretty much worthless.
Happy2Play 9811 Posted November 19, 2018 Posted November 19, 2018 (edited) Posted in other topic also but this may help. see second post https://emby.media/community/index.php?/topic/64167-roku-star-button-flashes-subtitles-menu Edited November 19, 2018 by Happy2Play
perry59 7 Posted November 19, 2018 Author Posted November 19, 2018 Ok, that explains it. too bad it has to map to a roku button instead of on the emby interface, oh well. thanks!
Happy2Play 9811 Posted November 19, 2018 Posted November 19, 2018 (edited) Ok, that explains it. too bad it has to map to a roku button instead of on the emby interface, oh well. thanks! You don't see it in the UI/OSD as discussed in second post of attached topic? Edited November 19, 2018 by Happy2Play
speechles 2062 Posted November 19, 2018 Posted November 19, 2018 (edited) So you expected to see the familiar "Audio & Subtitles" button like the old app? Or something else? On the video player On-Screen-Display (OSD) you can do this. To get there simply play the item, press down on your Roku remote, then navigate to the bottom row of action buttons. Choose the action you desire. These are the same action buttons used on all emby apps so they should be familiar. Are they? Do you find it hard to figure out how to get subtitles and audio stream changes to work for you? You said you also just got a Roku so it means you are new to Roku. We want to know on other Roku channels do you feel this same problem? Are we different than these other channels you use? Mostly in regards to how they allow you to choose subtitles and audio streams? I want to get a feeling how someone entirely new to Roku feels. We want to do better and better starts with most intuitive. Intuitive means no documentation is required because naturally you know how to use it. We want to be easy to use on the Roku. Please give more feedback on where you feel we are lacking. Thanks. Edited November 19, 2018 by speechles
ebr 16335 Posted November 19, 2018 Posted November 19, 2018 Hi. You don't see these buttons on your OSD?
perry59 7 Posted November 19, 2018 Author Posted November 19, 2018 You don't see it in the UI/OSD as discussed in second post of attached topic? I did try the "+" button which worked, but a bit clumsy. I did not try the "down" button, I'll try that tonight.
perry59 7 Posted November 19, 2018 Author Posted November 19, 2018 So you expected to see the familiar "Audio & Subtitles" button like the old app? Or something else? On the video player On-Screen-Display (OSD) you can do this. To get there simply play the item, press down on your Roku remote, then navigate to the bottom row of action buttons. Choose the action you desire. These are the same action buttons used on all emby apps so they should be familiar. Are they? Do you find it hard to figure out how to get subtitles and audio stream changes to work for you? You said you also just got a Roku so it means you are new to Roku. We want to know on other Roku channels do you feel this same problem? Are we different than these other channels you use? Mostly in regards to how they allow you to choose subtitles and audio streams? I want to get a feeling how someone entirely new to Roku feels. We want to do better and better starts with most intuitive. Intuitive means no documentation is required because naturally you know how to use it. We want to be easy to use on the Roku. Please give more feedback on where you feel we are lacking. Thanks. Yes I am new to roku. I expected the roku app to look and feel just like emby does on my computer. I did not know I had to push buttons on the roku controller to access things that are present on the computer interface but not on the emby app for roku.
perry59 7 Posted November 19, 2018 Author Posted November 19, 2018 Hi. You don't see these buttons on your OSD? not the very bottom row. but I did not press the "down" key on the roku controller. Did not know I had to do that. was hoping the roku interface would be identical to the chrome version. not a big deal, just didnt know I had to push a button on the controller.
mikeraburn 71 Posted November 19, 2018 Posted November 19, 2018 I have never seen the SPEAKER icon. Is that new in the past few days?
ebr 16335 Posted November 19, 2018 Posted November 19, 2018 I have never seen the SPEAKER icon. Is that new in the past few days? No. Been there since inception of this app. It will only be there if there are multiple audio tracks from which to choose, however.
mikeraburn 71 Posted November 19, 2018 Posted November 19, 2018 No. Been there since inception of this app. It will only be there if there are multiple audio tracks from which to choose, however. I understand now. I think I have a file like that. I'll see if it works if indeed the file has different audio. Learn something new everyday.
perry59 7 Posted November 20, 2018 Author Posted November 20, 2018 @@ebr I did see the OSD you show above when I hit the "down" button on the roku remote rather than the "*" button. I just wish the roku app could be just like the computer interface which is so nice, but I guess that is a roku limitation and not an emby thing. On the beautiful chrome interface I just set my parameters (if needed) and hit play. With roku you hit play first then interrupt the movie by setting parameters. Thanks!
ebr 16335 Posted November 21, 2018 Posted November 21, 2018 Hi. Selecting those options before playback will be coming in a future update. However, you may want to look into your default settings for audio and subtitles on the server so that, perhaps, they can be selected how you want automatically. Thanks.
