solabc16 379 Posted November 19, 2018 Posted November 19, 2018 Thanks for the update @@l0fL. @@mr_curator, diags and logs please, detailed above. Best - James
mr_curator 0 Posted November 20, 2018 Posted November 20, 2018 sendlogs_Storage3_synology_broadwell_3617xs_20181120T030903UTC.tgz after diag sendlogs_Storage3_synology_broadwell_3617xs_20181120T031424UTC.tgz
solabc16 379 Posted November 20, 2018 Posted November 20, 2018 Hello @@mr_curator Thanks for the logs, the issue is being caused by an image processing failure (SIGSEGV) whilst attempting to create a collage. 2018-11-20 06:13:49.979 Info ImageProcessor: Creating image collage and saving to /var/packages/EmbyServer/target/var/cache/temp/4a77b12c10bc4caeb91eda1793ade438.png Stacktrace: at <unknown> <0xffffffff> at (wrapper managed-to-native) SkiaSharp.SkiaApi.sk_codec_new_from_stream (intptr) [0x00002] in <7d2e3bd6812e4881b5c49a3f02b476aa>:0 at SkiaSharp.SKCodec.Create (SkiaSharp.SKStream) [0x00014] in <7d2e3bd6812e4881b5c49a3f02b476aa>:0 at SkiaSharp.SKBitmap.Decode (SkiaSharp.SKStream) [0x0000e] in <7d2e3bd6812e4881b5c49a3f02b476aa>:0 at SkiaSharp.SKBitmap.Decode (string) [0x00015] in <7d2e3bd6812e4881b5c49a3f02b476aa>:0 at Emby.Drawing.Skia.SkiaEncoder.Decode (string,bool,MediaBrowser.Model.IO.IFileSystem,MediaBrowser.Model.Logging.ILogger,System.Nullable`1<MediaBrowser.Model.Drawing.ImageOrientation>,SkiaSharp.SKCodecOrigin&) [0x00103] in <5145ae7a9a5847e497326bf760c58178>:0 at Emby.Drawing.Skia.StripCollageBuilder.GetNextValidImage (string[],int,int&) [0x00013] in <5145ae7a9a5847e497326bf760c58178>:0 at Emby.Drawing.Skia.StripCollageBuilder.BuildSquareCollageBitmap (string[],int,int) [0x00028] in <5145ae7a9a5847e497326bf760c58178>:0 at Emby.Drawing.Skia.StripCollageBuilder.BuildSquareCollage (string[],string,int,int) [0x00000] in <5145ae7a9a5847e497326bf760c58178>:0 at Emby.Drawing.Skia.SkiaEncoder.CreateImageCollage (MediaBrowser.Controller.Drawing.ImageCollageOptions) [0x0008c] in <5145ae7a9a5847e497326bf760c58178>:0 at Emby.Drawing.ImageProcessor.CreateImageCollage (MediaBrowser.Controller.Drawing.ImageCollageOptions) [0x0001f] in <82dd8d47dc2142bd8e90482cc30adca4>:0 at Emby.Server.Implementations.Images.BaseDynamicImageProvider`1<T_REF>.CreateCollage (MediaBrowser.Controller.Entities.BaseItem,System.Collections.Generic.List`1<MediaBrowser.Controller.Entities.BaseItem>,string,int,int) [0x00067] in <8252e50122f84f82af882c36d707f6ce>:0 Is your XPEnology system running as a bare metal installation or virtualised? Best - James
mr_curator 0 Posted November 20, 2018 Posted November 20, 2018 Hello my system running as a bare metal. Best Serge
n00b42 41 Posted November 20, 2018 Author Posted November 20, 2018 @@solabc16 Was able to start 3.5.3.0-20, so far no issues As requested: rundiags & sendlogs: sendlogs_BigAssStorage_synology_bromolow_3615xs_20181120T193908UTC.tgz
solabc16 379 Posted November 20, 2018 Posted November 20, 2018 Thanks for the logs @@n00b42, the system appears to be running well. Best - James
l0fL 0 Posted November 21, 2018 Posted November 21, 2018 @@solabc16 It seems to work without any problems. Here are my logs after rundiags sendlogs_NAS_synology_bromolow_3615xs_20181121T112128UTC.tgz Thank you solabc!
solabc16 379 Posted November 21, 2018 Posted November 21, 2018 Thanks for the update @@l0fL, logs look good. Best - James
