Luke 42245 Posted January 1, 2019 Posted January 1, 2019 That could be due to no tuner available. Anyway, much of that has been cleaned up and improved for the upcoming 3.6 release. Thanks.
KingKoopa08 17 Posted January 2, 2019 Author Posted January 2, 2019 @@Luke Do you know when 3.6 will be released in the stable channel? I am hesitant to switch to beta because I want to switch to your new epg I just don't know what changes I will need to make for it to match up channels automatically. Which took me a few weeks to get it down for schedules direct. Thanks, Kaecey
Luke 42245 Posted January 2, 2019 Posted January 2, 2019 Hopefully soon. We're going as fast as we can. Thanks.
KingKoopa08 17 Posted January 3, 2019 Author Posted January 3, 2019 @@Luke I just reproduced this issue on the latest beta. I updated last night. I have provided the two logs. directstream.txt server.txt
Luke 42245 Posted January 3, 2019 Posted January 3, 2019 Try enabling the stream looping option on the m3u tuner. Thanks.
KingKoopa08 17 Posted January 3, 2019 Author Posted January 3, 2019 @@Luke So far so good. I will continue testing and let you know. Thanks!
KingKoopa08 17 Posted January 5, 2019 Author Posted January 5, 2019 @@Luke Unfortunately, I ran into it again last night but for some reason, I must have forgotten to click post. This is the error that was showing. 2019-01-03 19:44:25.908 Error HttpServer: Error processing request *** Error Report *** Version: 3.6.0.82 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.9.144.6 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 8 Program data path: /var/lib/emby Application directory: /opt/emby-server/system MediaBrowser.Common.Extensions.ResourceNotFoundException: MediaBrowser.Common.Extensions.ResourceNotFoundException: Exception of type 'MediaBrowser.Common.Extensions.ResourceNotFoundException' was thrown. at Emby.Server.Implementations.Library.MediaSourceManager.GetLiveStreamInfo(String id, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.GetLiveStreamWithDirectStreamProvider(String id, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.GetLiveStream(String id, CancellationToken cancellationToken) at Emby.Server.MediaEncoding.Api.MediaInfoService.GetPlaybackInfo(BaseItem item, User user, Boolean allowMediaProbe, String mediaSourceId, String liveStreamId) at Emby.Server.MediaEncoding.Api.MediaInfoService.GetPlaybackInfo(GetPostedPlaybackInfo request) at Emby.Server.MediaEncoding.Api.MediaInfoService.Post(GetPostedPlaybackInfo request) at Emby.Server.Implementations.Services.ServiceExecGeneral.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, ILogger logger, String operationName, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, String urlString, String host, String localPath, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() at Emby.Server.Implementations.Library.MediaSourceManager.GetLiveStreamInfo(String id, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.GetLiveStreamWithDirectStreamProvider(String id, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.GetLiveStream(String id, CancellationToken cancellationToken) at Emby.Server.MediaEncoding.Api.MediaInfoService.GetPlaybackInfo(BaseItem item, User user, Boolean allowMediaProbe, String mediaSourceId, String liveStreamId) at Emby.Server.MediaEncoding.Api.MediaInfoService.GetPlaybackInfo(GetPostedPlaybackInfo request) at Emby.Server.MediaEncoding.Api.MediaInfoService.Post(GetPostedPlaybackInfo request) at Emby.Server.Implementations.Services.ServiceExecGeneral.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, ILogger logger, String operationName, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, String urlString, String host, String localPath, CancellationToken cancellationToken) directstream2.txt server2.txt
KingKoopa08 17 Posted January 7, 2019 Author Posted January 7, 2019 Yeah, I just had it happen again. server.txt directstream.txt
KingKoopa08 17 Posted January 8, 2019 Author Posted January 8, 2019 @@Luke I apologize for the delayed response. Yes it is.
Luke 42245 Posted January 8, 2019 Posted January 8, 2019 Are you sure it's just not a problem in the source stream?
KingKoopa08 17 Posted January 8, 2019 Author Posted January 8, 2019 @@Luke Yes very confident. How I know this is I load the stream on my desktop. Then I load the stream on emby the stream stops on emby but continually plays on both hls extension on chrome and vlc player.
deecemobile 3 Posted January 9, 2019 Posted January 9, 2019 I'm just butting in here to concur with KingKoopa08 that my IPTV streams randomly stop playing in Emby and just go to a black screen but this does not happen in VLC.
KingKoopa08 17 Posted January 11, 2019 Author Posted January 11, 2019 @@Luke Is there anything else we can look at?
KingKoopa08 17 Posted January 12, 2019 Author Posted January 12, 2019 @@LukeI want to say yes but don't specifically remember. I will try that today and see what I come up with. Thanks man!
KingKoopa08 17 Posted January 12, 2019 Author Posted January 12, 2019 @@Luke If it is easier to help troubleshoot. I wouldn't have a problem sharing some of the streams with you to try if you can debug easier on your end. Not that I am saying you have to just throwing that out there.
KingKoopa08 17 Posted January 12, 2019 Author Posted January 12, 2019 @@Luke, I just tested on web app vs my mi box (android tv latest update). Web app no issue. Android TV did have the issue.
Luke 42245 Posted January 13, 2019 Posted January 13, 2019 what if you lower the quality setting in the android tv app so that the server does a full transcode?
KingKoopa08 17 Posted January 13, 2019 Author Posted January 13, 2019 @@Luke Yeah, I tried that and it still happens. One thing I didn't mention prior are my streams are HLS streams. Not sure if that makes a difference in troubleshooting.
KingKoopa08 17 Posted January 19, 2019 Author Posted January 19, 2019 @@Luke, Any other ideas we could look at to get this addressed?
Luke 42245 Posted January 19, 2019 Posted January 19, 2019 @@Luke Yeah, I tried that and it still happens. One thing I didn't mention prior are my streams are HLS streams. Not sure if that makes a difference in troubleshooting. Are you able to configure this?
KingKoopa08 17 Posted January 19, 2019 Author Posted January 19, 2019 @@Luke, I would be happy to do anything. I am not sure what you mean able to configure this. Could you give me more info please?
