bhajipav 1 Posted November 16, 2018 Posted November 16, 2018 (edited) I have a zotac 1080 mini, and I am using emby on my desktop to stream movies at work. I mainly just listen to them at a lower quality using mxplayer. My question when I use gpu transcoding it is over 80% load. Is that safe to do for 8 hours at a time? or is there a better transcoding option for me since all I am doing is listening to the movie? BTW I have a i7 6700k paired with it.Kodi TutuApp AppValley Edited November 16, 2018 by bhajipav
Luke 42246 Posted November 16, 2018 Posted November 16, 2018 Hi, yes that should be fine. @@softworkz may have some insight. Thanks.
softworkz 5133 Posted November 16, 2018 Posted November 16, 2018 (edited) I have a zotac 1080 mini, and I am using emby on my desktop to stream movies at work. I mainly just listen to them at a lower quality using mxplayer. My question when I use gpu transcoding it is over 80% load. Is that safe to do for 8 hours at a time? or is there a better transcoding option for me since all I am doing is listening to the movie? BTW I have a i7 6700k paired with it. Generally any processor could run at 100% for years - as long as it's cooled well. The only issues are thermal ones and in this regard I can't say anything about your specific hardware. But what you can do is activate throttling. This will slow down transcoding and only transcode as much as needed to keep up continuous playback. Edited November 16, 2018 by softworkz
