riverboat2001 20 Posted November 15, 2018 Posted November 15, 2018 I'm sure there's a reason for this, but: Emby Theatre server on Windows 10 on BBC1 and BBC 2 if I watch live TV I get the correct English channel, if I watch a recorded show in the TV Shows section I get a little music note, I click on that and I can select the correct audio stream. The problem comes with watching something recorded earlier on that day, it doesn't show up in the TV Shows section (I assume because until a refresh is run it doesn't know it's there.So I have to watch it via the Nextpvr option and sure enough the show is there, but I'm stuck with the NAR track with no option to switch tracks. Is it viable to have the refresh run every 60 mins, or is there something else I can do? (I have to use nextpvr because of the tuner card I have)
Luke 42216 Posted November 16, 2018 Posted November 16, 2018 Hi, you could try using the real-time monitor, and/or adjusting the schedule of the library scan to better fit your recording schedule. Please let us know if this helps. Thanks.
