mypanasonic 8 Posted November 15, 2018 Posted November 15, 2018 i've had to rollback the last 3 updates from Nvidia as the new drivers since release of the new RX range seem to have broken opengl on a number of programs. Retroarch been the worst ! I currently have issues when playing any content in emby theater. I have no error logs as its more of a glitch then a error for instance pressing the volume up / down keys on the keyboard seems to remove HDR ? and give the screen graphical glitches. Screen pixel blocking and very high contrast changes. pressing the volume key again resets the screen back to HDR dolby Vision picture mode. im currently using a GTX1080 As mentioned rolling back the driver to end of September seems to stop the issues
Guest asrequested Posted November 15, 2018 Posted November 15, 2018 I'm assuming you are talking about Theater for desktop? If yes, that's more of an ffmpeg issue. I can possibly help you with that. But if you're talking about the store app, that's different. I have a GTX 1060 and I can play everything just fine, but I've made a lot of tweaks.
Guest asrequested Posted November 15, 2018 Posted November 15, 2018 What hardware acceleration were you using?
mypanasonic 8 Posted November 15, 2018 Author Posted November 15, 2018 NVENC ewa_lanczossharp ewa_lanczossharp
Guest asrequested Posted November 15, 2018 Posted November 15, 2018 Oh, I thought we were talking about using Theater? Not server transcoding. Or did you mean nvdec?
mypanasonic 8 Posted November 15, 2018 Author Posted November 15, 2018 (edited) yeah sorry nvdec (copyback) testing it everything works fine until you select opengl highend profile it then seems to break and by that i mean it wont work again even when de-selecting opengl highend profile only way i can get it to work again is by uninstalling, and removing appdata remains then re-installing i have tried mvp (standalone) with highend profile enabled in config and it runs fine and channel switches are instant. Edited November 15, 2018 by mypanasonic
Guest asrequested Posted November 15, 2018 Posted November 15, 2018 Oh that's what you're talking about. That's just a quick scaling option. You don't want to use that with the other scaling options. It's misleading. It's not opengl, it's opengl scalers.
Guest asrequested Posted November 15, 2018 Posted November 15, 2018 (edited) A lot of those UI options should be removed. A lot of people are getting confused on how to use them. Any power user can use them in an mpv.conf, if they really want to use them. Edited November 16, 2018 by Doofus
Guest asrequested Posted November 15, 2018 Posted November 15, 2018 The opengl API may not even be used. There's an auto selection that mpv makes behind the scenes. There is a way to control all of that. That's what I do.
