jhildenburg 0 Posted April 17, 2014 Posted April 17, 2014 I have The Hobbit in two different formats. H.264 MKV DVD Quality and H.264 MKV Blu-ray Quality. I have them grouped together and that part seems to be working. When I enabled CoverArt it shows up as a H.264 (like all my other titles). I went into the CoverArt config and changed it to display based on quality instead of type. I then changed it so SD comes up as DVD and HD comes up as BD. This works for all my single title movies (standard def is DVD and high def is Blu-Ray) but not for the grouped together Hobbit. It shows up as DVD. I would like it show the format based on the highest quality in the group. Is there a way to do this? Thanks
Solution ebr 16344 Posted April 17, 2014 Solution Posted April 17, 2014 Not yet. The grouping is a brand new concept and CoverArt doesn't understand it yet. I will have to figure out how best to deal with it. The server is the one who decides which one of your versions is the "primary" one though and I'm not sure how it is making that determination at this point. Perhaps it is the one that you use as the base when you set up the grouping so you could try changing that. 2
jhildenburg 0 Posted April 17, 2014 Author Posted April 17, 2014 Perhaps it is the one that you use as the base when you set up the grouping so you could try changing that. That worked!!! I ungrouped them and checked the Blu-ray title first when I grouped them back. CoverArt now recognizes it as HD quality. Thanks for a great answer
