jlc510 0 Posted November 15, 2018 Posted November 15, 2018 I just installed Emby on my Samsung Smart TV, but I don't see where I can make a play list or filter by specific year like I can when I use Emby on my Win 10 PC. Is there something I'm missing?
k0Lm. 32 Posted November 15, 2018 Posted November 15, 2018 At this moment we cannot do that with the samsung tv app.
FrostByte 5453 Posted November 15, 2018 Posted November 15, 2018 What version of the app are you running? You should be able to filter by year All Movies Select Filter toward upper right Scroll down and select Year A list of all years should appear
Luke 42241 Posted November 15, 2018 Posted November 15, 2018 If it's not there, then it will be in the next update to the app. Thanks !
