BillOatman 597 Posted November 15, 2018 Posted November 15, 2018 (edited) I was watching iptv and channel surfing. Streams were playing perfectly. At one point I watched one recording of a TV show. Everything perfect. Then the stream stopped, and my shield was unable to get any guide info from the server. I remoted into the server and the response was horrifically slow, memory usage was pegged as you can see in the attached image. It was actually over 90% when task manager first came up. I had to kill the emby server with task manager, then restart. It has been fine after the restart. I have attached the log. There are a bunch of exceptions near the bottom. emby log.txt Edited November 15, 2018 by BillOatman
Happy2Play 9806 Posted November 15, 2018 Posted November 15, 2018 By change is your drive Emby is installed on full?
BillOatman 597 Posted November 15, 2018 Author Posted November 15, 2018 By change is your drive Emby is installed on full? No.
BillOatman 597 Posted November 15, 2018 Author Posted November 15, 2018 (edited) How many live tv channels do you have? 100-150 2 DVRs, 1 hdhomerun (10 or so channels) and 1 IPTV. I had not watched any of the homerun channels, only IPTV. And I had only one client ruining last night, a shield, Edited November 15, 2018 by BillOatman
Luke 42214 Posted November 15, 2018 Posted November 15, 2018 Strange. Nothing crazy there. Can you try disabling the server's dlna features and then restart the server and see if it happens again? Thanks.
BillOatman 597 Posted November 15, 2018 Author Posted November 15, 2018 Strange. Nothing crazy there. Can you try disabling the server's dlna features and then restart the server and see if it happens again? Thanks. I can and will. But this is the first time it has ever happened. Just to be sure, follow the instructions here for turning off, correct? https://www.isunshare.com/windows-10/turn-on-or-off-media-streaming-in-windows-10.html
Happy2Play 9806 Posted November 15, 2018 Posted November 15, 2018 I can and will. But this is the first time it has ever happened. Just to be sure, follow the instructions here for turning off, correct? https://www.isunshare.com/windows-10/turn-on-or-off-media-streaming-in-windows-10.html No that is for Windows. Emby's DLNA server option is Dashboard-DLNA-Enable Dlna server
BillOatman 597 Posted November 15, 2018 Author Posted November 15, 2018 No that is for Windows. Emby's DLNA server option is Dashboard-DLNA-Enable Dlna server Even easier, glad I asked. Thanks.
BillOatman 597 Posted November 15, 2018 Author Posted November 15, 2018 Strange. Nothing crazy there. Can you try disabling the server's dlna features and then restart the server and see if it happens again? Thanks. So nothing unusual about the exceptions in the log?
Luke 42214 Posted November 18, 2018 Posted November 18, 2018 Well this one you won't see anymore with the next release 2018-11-14 20:22:42.951 Error App: Error receiving udp message *** Error Report *** Version: 3.5.3.0 Command line: C:\Users\woatm\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 12 Program data path: C:\Users\woatm\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\woatm\AppData\Roaming\Emby-Server\system System.InvalidOperationException: EndReceiveFrom can only be called once for each asynchronous operation. at System.Net.Sockets.Socket.EndReceiveFrom(IAsyncResult asyncResult, EndPoint& endPoint) at Emby.Server.Implementations.Net.UdpSocket.EndReceive(IAsyncResult result) at Emby.Server.Implementations.Udp.UdpServer.OnReceiveResult(IAsyncResult result) System.InvalidOperationException at System.Net.Sockets.Socket.EndReceiveFrom(IAsyncResult asyncResult, EndPoint& endPoint) at Emby.Server.Implementations.Net.UdpSocket.EndReceive(IAsyncResult result) at Emby.Server.Implementations.Udp.UdpServer.OnReceiveResult(IAsyncResult result) And then a couple others are due to requests to your iptv urls either timing out or being rejected by their server. 1
