Luke 42244 Posted November 27, 2018 Posted November 27, 2018 Can you please attach the emby server log? thanks.
omn1slash 1 Posted November 27, 2018 Posted November 27, 2018 Hi all - I am new to Emby (just installed today) and I am having the exact same problems minus the NPVR plugin. I have NPVR installed on the same machine (was what I was formerly using) but in Emby I've plugged the M3U and the EPG in directly. At first I was getting the "no compatible stream" error all the time. I then restarted the server, and some channels work... most of the time. It takes about 5-10 seconds to load (which I can be fine with) but sometimes the channel refuses to load and you just see a "Spinning icon" on screen indefinitely. I then got TruTV to work for about 90 minutes, then the channel just magically stopped. I then tried to reload and spinning circle. I tested on NPVR/Kodi right after, and this channel works fine. My situation may be slightly different from the OP, but I'm having similar issues.
EODCrafter 181 Posted November 28, 2018 Posted November 28, 2018 @@omn1slash Can you please attach the emby server log? thanks.
omn1slash 1 Posted November 28, 2018 Posted November 28, 2018 Sure - here you go. Thanks for any time in help solving this in advance. embyserver.txt 1
Luke 42244 Posted December 9, 2018 Posted December 9, 2018 Sure - here you go. Thanks for any time in help solving this in advance. @@omn1slash is your iptv provider only allowing one connection? Thanks.
