BillOatman 597 Posted November 14, 2018 Posted November 14, 2018 Is there a rest api that will allow me to tell the server to refresh the livetv guide from its sources?
Solution Happy2Play 9811 Posted November 14, 2018 Solution Posted November 14, 2018 Have you looked at the ScheduledTaskService? /ScheduledTasks/Running/{Id} Starts a scheduled task At the bottom of the Dashboard there is a link to the API. 2
BillOatman 597 Posted November 15, 2018 Author Posted November 15, 2018 (edited) Thanks! The swagger UI being available from that main page is pretty cool as well. I see I can get the list of scheduled tasks then run the refresh guide one. Should work out fine, thanks again. Edited November 15, 2018 by BillOatman
