jonomite 29 Posted November 13, 2018 Posted November 13, 2018 (edited) I am using the Emby app on a Samsung smart TV. I have several audio files encoded in Opus format that I'd like to play. However, when I try to load a file, I get an error message stating that there is no compatible audio format. I assume this means that the Samsung smart TV doesn't natively support the Opus codec. However, shouldn't Emby detect that and transcode to a codec that will work? Or is that only the case with video? Thanks! Sent from my Nexus 5X using Tapatalk Edited November 14, 2018 by jonomite
Luke 42214 Posted November 14, 2018 Posted November 14, 2018 Hi, yes we should be. What model Samsung and what version of the app? Thanks.
jonomite 29 Posted November 14, 2018 Author Posted November 14, 2018 (edited) Hey @@Luke, The model number of the television is UN55KU6290FXZA. The Emby app version is 4.1. Sent from my Nexus 5X using Tapatalk Edited November 14, 2018 by jonomite
Luke 42214 Posted November 14, 2018 Posted November 14, 2018 4.1, are you sure? Where are you seeing that? We don't have a version 4.1. Thanks.
jonomite 29 Posted November 14, 2018 Author Posted November 14, 2018 4.1, are you sure? Where are you seeing that? We don't have a version 4.1. Thanks.Woops! I was looking at the star rating. Where would I look to find the version of the app? Sent from my Nexus 5X using Tapatalk
jonomite 29 Posted November 14, 2018 Author Posted November 14, 2018 4.1, are you sure? Where are you seeing that? We don't have a version 4.1. Thanks.Okay, I think I found it. It looks like it's Emby Theater 1.0.45. Sent from my Nexus 5X using Tapatalk
Luke 42214 Posted November 14, 2018 Posted November 14, 2018 Ok, please try again with the next update to the app. Thanks.
SamES 1082 Posted November 15, 2018 Posted November 15, 2018 @@jonomite, could you please post the mediainfo of a sample. I'm interested in the container and codec formats. Thanks
Luke 42214 Posted November 15, 2018 Posted November 15, 2018 Or better yet just zip up a sample file and provide one. Should be small enough to do that. Thanks !
jonomite 29 Posted November 17, 2018 Author Posted November 17, 2018 Okay. I'm away from my computer for a little while, but will try to upload one. FWIW, it's an opus file encoded with the latest version (1.3). Sent from my Nexus 5X using Tapatalk
