nabsboss 2 Posted April 16, 2014 Posted April 16, 2014 hi, i have my media located on a synology with ip 192.168.0.100 My MB3 server is installed on a pc with ip 192.168.0.101 So my library in MB3 is configured with unc \\192.168.0.100\movie I can direct play my files since the pc over the file browser or mozzilla with unc path only. But when i use the web player of MB3, it always transcode the mkv files. Can you help me and tell me if i did something wrong please !? Thanks a lot
Luke 42176 Posted April 16, 2014 Posted April 16, 2014 unfortunately the browser can't access the file system which is why your'e seeing the transcoding.
nabsboss 2 Posted April 17, 2014 Author Posted April 17, 2014 (edited) Hi Luke, Thanks for your reply ! Web browser should access file system when you use unc, isn't ? Like i tested, it works fine with mozilla. I find that the MB3 player can direct play mkv if you change static=false to static=true without transcoding with ffmpeg: http://localhost:8096/mediabrowser/Videos/e153c76527271d393b9973cd1e57c30b/stream.webm?audioChannels=2&SubtitleStreamIndex=3&AudioStreamIndex=1&deviceId=4ef7f953d576e3400cf007b2691f589497e86cac&Static=true&mediaSourceId=e153c76527271d393b9973cd1e57c30b&VideoCodec=vpx&AudioCodec=Vorbis&maxWidth=1920&videoBitrate=1372000&audioBitrate=128000&EnableAutoStreamCopy=false I changed maxWidth=1280 to maxWidth=1920 too for full hd. Can you confirm it in your side and change it if it's ok for you ? Edit: It works if the browser use the vlc plugin ! Then it will be great for people that have the pluggin instaled to use this feature, what you think ? Edit:2 hope that ORBX.js coming soon this summer to said bye bye to ffmpeg Edited April 16, 2014 by nabsboss
nabsboss 2 Posted April 18, 2014 Author Posted April 18, 2014 Ok , i understand ! I juste want help. Like i said, i hope that orbx.JS (release open source on github this summer) will be the ultimate solution Thanks Luke and all team for your hard work
Luke 42176 Posted April 19, 2014 Posted April 19, 2014 we are doing everything possible to direct stream when we can in a way that works across a broad range of browser and devices. and we're going to keep working on improving it.
