Redarmy 2 Posted November 12, 2018 Posted November 12, 2018 So, I recently switched from cox cable's 300Mbps/down connection to their "gigablast" connection and ever since doing so, I've been unable to connect to Emby anywhere, locally or remotely. I forwarded the proper ports, and then tried disabling firewall and dmz and nothing can connect, though other local devices will see the server, nothing can connect. Am I doing something wrong/forgetting something?
Redarmy 2 Posted November 12, 2018 Author Posted November 12, 2018 Yes, but I already updated what IP to try to connect to. Set a reserved local IP for the server to make sure everything can connect to it properly...
Sammy 791 Posted November 12, 2018 Posted November 12, 2018 I think @ is talking about your external ip address. Sent from my SM-G930P using Tapatalk
ebr 16312 Posted November 12, 2018 Posted November 12, 2018 Yeah, and it is probably defaulting to an IPv6 address as well.
Redarmy 2 Posted November 12, 2018 Author Posted November 12, 2018 I don't see why external IP address should matter on a LAN connection, but yes it changed when I changed plans. I have IPv6 disabled for it, so it's not that.
SEIFHD 0 Posted November 13, 2018 Posted November 13, 2018 (edited) THANKS ShowBox Mobdro TutuApp Edited November 13, 2018 by SEIFHD
Redarmy 2 Posted November 13, 2018 Author Posted November 13, 2018 Well, I've tried everything I can think of short of changing out my router, which I plan to do.
