Mike5123 1 Posted November 11, 2018 Posted November 11, 2018 (edited) On debian 9.5 64bit using the xanmod kernel (to allow the i915 driver to load) Emby will not hardware transcode (either stable or beta version). Interestingly, Plex does hardware transcode. This is with a UHD 630. This test was with Emby 3.5.3.0. Quicksync does not work. VAAPI does not work. (1:503)# ls -l /dev/dri total 0 crw-rw---- 1 root video 226, 0 Nov 10 21:17 card0 crw-rw---- 1 root video 226, 128 Nov 10 21:17 renderD128 The setup is a little wonky compared to Ubuntu, but I can confirm Plex uses hardware transcoding on this node as intel_gpu_top shows usage. Emby can't transcode on the hardware, for whatever reason. Logs attached. Edited November 11, 2018 by Mike5123
Mike5123 1 Posted November 11, 2018 Author Posted November 11, 2018 Nope, same issue on Ubuntu. Okay, I'm out of ideas.
Luke 42246 Posted November 11, 2018 Posted November 11, 2018 Hi there, please see how to report a problem. thanks.
tdiguy 99 Posted November 13, 2018 Posted November 13, 2018 What sort of hardware transcoding are you trying to do? Are you trying to use VAAPI?
