daveoxford 1 Posted November 11, 2018 Posted November 11, 2018 (edited) Hi In TV shows in Emby (WebApp), if there is no primary image explicitly set for a particular season, it uses the primary image for the show instead (which is sensible).However, Emby for Kodi doesn't do this, but just displays a folder icon - and this overlaps the text "Season x" in certain views (InfoWall and Poster specifically)Is this a known issue, and will it be fixed, do we know?If not and/or in the meantime, is there a workaround? I don't want to have to manually set an image for every season in my library that hasn't got one, obviously! Can anybody help?Thanks very much,DaveP.S. Just checked EmbyCon, and it does the same. Edited November 11, 2018 by daveoxford
Angelblue05 4132 Posted November 11, 2018 Posted November 11, 2018 I suppose it's something emby for kodi could support.
