TheShanMan 41 Posted November 11, 2018 Posted November 11, 2018 Is there a guide on using Theater? I'm trying to figure out how to skip to a specific point in a video (e.g. skip to the 12 minute mark). I also want to know how to swap the skip fwd/back and ff/rew buttons. Skip is going to the next video in the playlist whereas ff/rew are doing skip.
EODCrafter 181 Posted November 11, 2018 Posted November 11, 2018 Is there a guide on using Theater? I'm trying to figure out how to skip to a specific point in a video (e.g. skip to the 12 minute mark). I also want to know how to swap the skip fwd/back and ff/rew buttons. Skip is going to the next video in the playlist whereas ff/rew are doing skip. All I could find is this, More like an Ad than a guide.
Luke 42242 Posted November 11, 2018 Posted November 11, 2018 There are currently no settings to configure button mappings.
TheShanMan 41 Posted November 11, 2018 Author Posted November 11, 2018 How do you skip to a certain point in a video, like if I want to jump to 12:00, how do I do that? In WMC you press 1-2-play. That doesn't work in Theater, at least not for me.
Luke 42242 Posted November 12, 2018 Posted November 12, 2018 Interesting, i was never even aware of that shortcut. Yes that's something that could be looked at. With a remote currently there is no way although a chapter menu is planned for the future. I also like the shortcut you just mentioned. 1
Guest asrequested Posted November 12, 2018 Posted November 12, 2018 This might be able to be used for that. https://mpv.io/manual/stable/#options-start
TheShanMan 41 Posted November 12, 2018 Author Posted November 12, 2018 I hope you'll decide to add it soon then! And it will provide a little more consistency across apps! Thanks Luke!
