dcol 176 Posted November 10, 2018 Posted November 10, 2018 (edited) Last night Emby started doing some weird things. So I looked into it and found out my M3U link was down. I fixed that, My TV guide now starts one day early, and I get a spinning circle for 5 minutes before the scheduled shows pop up. The actual recordings are ok in the guide. Also in the Android app the scheduled shows don't come up at all and If I look at recordings I get a Volley Error. Emby has also slowed down a lot doing anything since this happened. Tried using Emby on the same server with the same results. I must have to clean out something in Emby. Tried restarting Emby and the computer. Cleaned out the cache folder. refreshed the Guide and library. No difference What do I need to do? Edited November 10, 2018 by dcol
Luke 42214 Posted November 10, 2018 Posted November 10, 2018 Please see how to report a problem. thanks.
dcol 176 Posted November 10, 2018 Author Posted November 10, 2018 Fixed it. NextPVR plugin was looking at the wrong port. I should look at those logs more often.
