sector327 4 Posted November 8, 2018 Posted November 8, 2018 My emby server runs awesome. In a constant attempt to make my library better, I'd like to upgrade all of my 720p movies to 1080p. (By upgrade, I mean replace the 720p movies w/ a higher resolution version.) In reading around, it looks like the mp4 format might be best to use. I have plenty of storage so I'm not worried about space. As for transcoding, I have plenty of processor power to handle that (I think). Is there a way inside of Emby that I can search my libraries and see a list of the 720p movies (or rather a breaksdown of the various resolutions I have)? (and if not in Emby, does anyone have a recommendation of something I could use to handle such inventory?) thanks!
Solution Happy2Play 9806 Posted November 8, 2018 Solution Posted November 8, 2018 You could use the Reports plugin and export the list to excel or csv file. 1
Luke 42214 Posted November 9, 2018 Posted November 9, 2018 I'm sure we will expand on the built in filters in the future. Thanks. 1
