Rleibham 2 Posted November 8, 2018 Posted November 8, 2018 hello my shield has no sound and i cant find any sound options plz help
mastrmind11 722 Posted November 8, 2018 Posted November 8, 2018 hello my shield has no sound and i cant find any sound options plz help video but no sound? neither? what device is the client running on? is your server transcoding or direct playing? have you tried turning up the volume?
Sammy 791 Posted November 8, 2018 Posted November 8, 2018 I've been experiencing this recently on only one of my ShieldTV's and need to create a post but I suppose I'll just comment here. I will upload logs from the server and from the device but not until tomorrow at the earliest. 1
Jdiesel 1437 Posted November 8, 2018 Posted November 8, 2018 (edited) Also seen this last night when trying to watch live TV on multiple different channels. Played a local file right after with no issues. Will grab some logs next time it happens. Edit: I believe the audio for the live stream was 2-channel AAC Edited November 8, 2018 by Jdiesel
Rleibham 2 Posted November 8, 2018 Author Posted November 8, 2018 there video but no sound. it says surround is turned on but cant find any sound settings on server to turn off
Rleibham 2 Posted November 8, 2018 Author Posted November 8, 2018 where are the sound settings on server seems like there arenone i switched to emby because crappy plex because of there errors connection to server has been lost plz help!!
Jdiesel 1437 Posted November 8, 2018 Posted November 8, 2018 Do you have sound in any other apps on your Shield TV? Or it it just Emby that has no sound? 1
Rleibham 2 Posted November 8, 2018 Author Posted November 8, 2018 there is sound everywhere but the video there is sound with trailers too
Rleibham 2 Posted November 8, 2018 Author Posted November 8, 2018 it says the app is set too surround sound but cant find any sound settings 1
Sammy 791 Posted November 8, 2018 Posted November 8, 2018 yay i fixed itWhadja do? Sent from my SM-G930P using Tapatalk
Rleibham 2 Posted November 8, 2018 Author Posted November 8, 2018 i went into my sound settings under advanced and turned off surround sound those advanced sound settings were not there before 1
ebr 16337 Posted November 8, 2018 Posted November 8, 2018 i went into my sound settings under advanced and turned off surround sound those advanced sound settings were not there before Exactly where? 1
CBers 7554 Posted November 8, 2018 Posted November 8, 2018 Exactly where? Sounds (excuse the pun) like the Shield settings he's talking about. 1
