Lake 2 Posted November 8, 2018 Posted November 8, 2018 (edited) Hello, I have just installed emby app on my TV. When I try to log in the app say "bad password", althrough I am sure that the password is correct. The logs says : "Input string was not in a correct format." Love emby and it would be great if the smartTV app would work. Samsung Firmware Version TV Model : UE46F6320 (E series 2012) Samsung firware Version : Lastest 2126 Samsung Emby Client Version : 2.2.4 Thank you in advance for your help ! log.txt Edited November 8, 2018 by Lake
FrostByte 5453 Posted November 8, 2018 Posted November 8, 2018 TV Model : UE46F6320 (E series 2012) Not that it makes much a difference for this issue, but you actually have a F-series 2013. The "E" you see in that second column is for Europe.
FrostByte 5453 Posted November 8, 2018 Posted November 8, 2018 (edited) Are you using a connect userid to login by chance? If so, try a local account instead. If I remember correctly connect user login was never implemented in the older app. Edited November 8, 2018 by FrostByte
Lake 2 Posted November 8, 2018 Author Posted November 8, 2018 (edited) Are you using a connect userid to login by chance? If so, try a local account instead. If I remember correctly connect user login was never implemented in the older app. Not sure what is "userid login". I do not have many options on the App. At startup, it ask me the server address (or ip) and then it display the available users. I tried to log in with several users and as well with manual login. Edited November 8, 2018 by Lake
FrostByte 5453 Posted November 8, 2018 Posted November 8, 2018 Does it work with a user without a password?
Lake 2 Posted November 9, 2018 Author Posted November 9, 2018 (edited) Does it work with a user without a password? I did not try but in any cases, as the server is over internet, a password will be always required. Edited November 9, 2018 by Lake
FrostByte 5453 Posted November 9, 2018 Posted November 9, 2018 From what I remember connect or logging on remotely was never implemented in the community app
Lake 2 Posted November 9, 2018 Author Posted November 9, 2018 (edited) The logfie suggests the opposite. Look at the end : HTTP GET emby/Users/AuthenticateByName?format=json The problem is that the app use a GET http request instead of a POST request. Edited November 9, 2018 by Lake
FrostByte 5453 Posted November 9, 2018 Posted November 9, 2018 That's possible, just know the developer said it didn't work. Might be a quick fix
Lake 2 Posted November 9, 2018 Author Posted November 9, 2018 (edited) Okey. I will check the source code if it is available. Thank you Edited November 9, 2018 by Lake 1
FrostByte 5453 Posted November 9, 2018 Posted November 9, 2018 Unfortunately, the developer for that app is no longer around. The ability to login with connect and LiveTV were a couple of things that were being worked on before he left, but I don't think were fully developed. The code is on github if you are willing to take a look that would be great https://github.com/MediaBrowser/SamsungSmartTV
Lake 2 Posted November 9, 2018 Author Posted November 9, 2018 I (briefly) looked at the code and everything seems ok. Not sure but I think the issue come from the http->https redirection. (My server has Redirect rule in order to force https) When redirecting, xmlhttp strip the POST and send the request as GET. I am investigating 1
FrostByte 5453 Posted November 9, 2018 Posted November 9, 2018 Ya, https was another thing mentioned that was never added or finished
