snorkel 15 Posted November 7, 2018 Posted November 7, 2018 ever since I tried that new convert option a few months ago (maybe more) I get double groups for my TV recordings, for example The Good Place will be listed twice each with a badge showing 5 recordings. I totally disabled that convert stuff since it was not working properly and when I did have it I had it set to replace the content it converted not the side by side thing. Anyways, how can I fix this so I only have one group for a show? I am on the latest server version and latest android TV client.
Spaceboy 2573 Posted November 7, 2018 Posted November 7, 2018 Check your recorded tv folder in windows explorer. In about that timeframe it was decided that the year needed to be appended to the series name for each folder in your tv library.
snorkel 15 Posted November 12, 2018 Author Posted November 12, 2018 Ok, there was a bunch of extra folders in the library location, I deleted all the old ones and re scanned the library. They are gone, but will they pop up again? Are they also stored in a database? I know I removed them all from the GUI and they doubles started showing up again when new recordings happened.
Spaceboy 2573 Posted November 12, 2018 Posted November 12, 2018 As long as you deleted the ones without the year they won’t get recreated
