bluemonkey07 590 Posted May 15, 2014 Posted May 15, 2014 (edited) Another thing I just notified is that items listed the active movies and active episodes widgets will always start from the beginning when selected....when you would think the action should be to resume. Edit: Sorry I should mention that I'm using the modded confluence skin if that makes a difference. Edited May 15, 2014 by Vidman
im85288 1493 Posted May 16, 2014 Posted May 16, 2014 Another thing I just notified is that items listed the active movies and active episodes widgets will always start from the beginning when selected....when you would think the action should be to resume. Edit: Sorry I should mention that I'm using the modded confluence skin if that makes a difference. Can you post this is the confluence thread section? Otherwise it will just confuse this particular thread...cheers.
bluemonkey07 590 Posted May 16, 2014 Posted May 16, 2014 Can you post this is the confluence thread section? Otherwise it will just confuse this particular thread...cheers.Will do....I wasn't sure if it was a xbmb3c issue or a skin issue 1
bluemonkey07 590 Posted May 16, 2014 Posted May 16, 2014 I don't think your 'back' issue is related to this. These are the available sort orders: Album, AlbumArtist, Artist, Budget, CommunityRating, CriticRating, DateCreated, DatePlayed, PlayCount, PremiereDate, ProductionYear, SortName, Random, Revenue, Runtime 'SortName' is the default - the server is usually good about making this appropriate for the type of folder you are viewing - we typically do not override it in the client - but I can if everyone agrees PremiereDate is better for Seasons. @@Luke - comments? xnappo I didn't think it was related either but I thought I'd let you know about another possible bug:)
jose 73 Posted May 20, 2014 Posted May 20, 2014 I have been using this app for a while and i really like it. But the thing is i have been traveling a lot and this app works only when you are online. Would it be possible to add an option to download/cache a episode/season/series/movie for local playing from the same app? I know i can move the actual file to a local path and have xbmc read from there but it would be awsome i could just check a file while browsing it and the app started the download. Thanks for all the great work.
im85288 1493 Posted May 20, 2014 Posted May 20, 2014 I may be wrong, but I think in this case you would be better off having a local MB3 server for those occasions when you take the laptop away. Offline synch is probably something better suited to mobile apps such as the iPad/Android versions rather than this addon where the whole point is to replace the need for a local xbmc library.
Ballistic 8 Posted May 23, 2014 Posted May 23, 2014 Being able to filter movies would be awesome! Like; Genres, Year and Actor.
xnappo 1611 Posted May 23, 2014 Posted May 23, 2014 Being able to filter movies would be awesome! Like; Genres, Year and Actor. It is in the context menu. xnappo
goibe 0 Posted June 3, 2014 Posted June 3, 2014 (edited) Thanks for this great plugin. Suport for cu lcr lyrics would be nice! Thanks. Edited June 3, 2014 by goibe
