elcabong 48 Posted April 21, 2014 Posted April 21, 2014 ive noticed an issue with data going to xbmc in 1 instance: when playing an un-played episode, the plot gets passed so it can be called using xbmc's json > player.getitem. but if i stop the episode, creating a resume point, when resuming the episode, plot is not available through xbmc's json > player.getitem. i know getting the info through xbmc's json is a small use case, but it would make implementing something like the link below a bit easier instead of hitting xbmc for nowplaying, then mbs3 json for the rest of the data: http://forum.xbmc.org/showthread.php?tid=153126 requested info: cover, fanart, genre, year, first aired/released, runtime, rating, director, writer ive tried poking around line 885 in xbmb3c/default.py to add the additional info, but have been unsuccessful.
xnappo 1611 Posted April 21, 2014 Posted April 21, 2014 (edited) ive tried poking around line 885 in xbmb3c/default.py to add the additional info, but have been unsuccessful. I think I see the problem. Look for this: while xbmc.Player().getTime() < (seekToTime - 5): xbmc.Player().pause xbmc.sleep(100) xbmc.Player().seekTime(seekToTime) xbmc.sleep(100) xbmc.Player().play() Replace with this (only last line differs): while xbmc.Player().getTime() < (seekToTime - 5): xbmc.Player().pause xbmc.sleep(100) xbmc.Player().seekTime(seekToTime) xbmc.sleep(100) xbmc.Player().play(playurl, item) It that works, let me know and I will check it in. xnappo Edited April 21, 2014 by xnappo
elcabong 48 Posted April 22, 2014 Posted April 22, 2014 tested search, working fast here as well. looks good.. can you sort the results alphabetically until a better sort function is determined? this should put all like items next to each other, and keep multiple episodes of shows next to each other.
elcabong 48 Posted April 22, 2014 Posted April 22, 2014 nope, same issue persists. here is the json output from player.getitem the first time its played {"id":"1","jsonrpc":"2.0","result":{"item":{ "album":"", "artist":[], "cast":[], "country":[], "dateadded":"", "director":[], "episode":1, "episodeguide":"", "fanart":"", "file":"smb://myserver/TV Shows/Orphan Black/Season 02/Orphan Black - 2x01 - Nature Under Constraint and Vexed.mkv", "firstaired":"", "genre":[], "imdbnumber":"", "label":"Nature Under Constraint and Vexed", "lastplayed":"", "mpaa":"", "originaltitle":"", "playcount":0, "plot":"Sarah is out of options, on the run, and pursued by deadly adversaries. Desperate to find her daughter Kira, Sarah suspects ruthless pro-clone Rachel is behind her daughter’s disappearance and sparks an all out war against her. Alison and Donnie attend the funeral of her fallen friend, Aynsley, causing Alison to sink into guilt and despair. Cosima is faced with a perplexing decision that may have dire consequences.", "plotoutline":"", "premiered":"", "productioncode":"", "rating":0, "resume":{"position":0,"total":0}, "runtime":0, "season":2, "set":"", "setid":-1, "showlink":[], "showtitle":"", "sorttitle":"", "streamdetails":{"audio":[],"subtitle":[],"video":[]}, "studio":[], "tag":[], "tagline":"", "thumbnail":"image://http%3a%2f%2flocalhost%3a15001%2f%3fid%3d6f810ae9de86b8bf51c20fdcb92ac855%26type%3dPrimary%26tag%3d1743bb95263846a8798036b703db7198/", "title":"Nature Under Constraint and Vexed", "top250":0, "track":-1, "trailer":"", "tvshowid":-1, "type":"unknown", "uniqueid":{"unknown":""}, "votes":"", "writer":[], "year":0}}} and here is the json output from player.getitem each time after the first. i think it may have something to do with the lastplayed field handling. seems to be the only new info, while a bit of the previous info is missing {"id":"1","jsonrpc":"2.0","result":{"item":{ "dateadded":"", "director":[], "episode":-1, "episodeguide":"", "fanart":"", "file":"smb://myserver/TV Shows/Orphan Black/Season 02/Orphan Black - 2x01 - Nature Under Constraint and Vexed.mkv", "firstaired":"", "genre":[], "imdbnumber":"", "label":"Orphan Black - 2x01 - Nature Under Constraint and Vexed", "lastplayed":"2014-04-21 14:58:23", "mpaa":"", "originaltitle":"", "playcount":0, "plot":"", "plotoutline":"", "premiered":"", "productioncode":"", "rating":0, "resume":{"position":0,"total":0}, "runtime":0, "season":-1, "set":"", "setid":-1, "showlink":[], "showtitle":"", "sorttitle":"", "streamdetails":{"audio":[],"subtitle":[],"video":[]}, "studio":[], "tag":[], "tagline":"", "thumbnail":"image://http%3a%2f%2flocalhost%3a15001%2f%3fid%3d6f810ae9de86b8bf51c20fdcb92ac855%26type%3dPrimary%26tag%3d1743bb95263846a8798036b703db7198/", "title":"", "top250":0, "track":-1, "trailer":"", "tvshowid":-1, "type":"unknown", "uniqueid":{"unknown":""}, "votes":"", "writer":[], "year":0}}}
xnappo 1611 Posted April 22, 2014 Posted April 22, 2014 I played with that myself, but it wasn't very good - because you end up with a bunch of songs first. I will keep messing with it though - I agree it needs some sort of refinement. xnappo
elcabong 48 Posted April 22, 2014 Posted April 22, 2014 what about reverse alpha? would put the order like this (at least for my test results) tv series > music artists > movies > folder (collections if grouped in folders) > episodes > audio
xnappo 1611 Posted April 22, 2014 Posted April 22, 2014 Well I am hesitant to code around it - it is really an MB3 server limitation. Try a search in the Web client and you get the same result. With all of the non-standard queries I would like to see sorting ability added - like for NextUp I would like to be able to sort by series name... xnappo 1
elcabong 48 Posted April 22, 2014 Posted April 22, 2014 ah, i didnt think to check it against the web version.. i see what you mean. having just what you implemented is a huge plus already. if/when the time comes to look into this again, let me know if there is a request to add functionality to mbs3 search, il +1.
xnappo 1611 Posted April 22, 2014 Posted April 22, 2014 From all I can tell there is nothing wrong with our code... The information shows up correctly during playback, so I think it may be on the XBMC side. xnappo
xnappo 1611 Posted April 22, 2014 Posted April 22, 2014 (edited) Just read the following post in the XBMB3C thread on the XBMC forums: AFAIK there still isn't a favorite TV shows list node, right? I think it's a good suggestion. That is such an obvious and easy feature it is sneaking its way past 0.9.0 feature freeze It is in the Git now. Helps that I want it xnappo Edited April 22, 2014 by xnappo 1
elcabong 48 Posted April 22, 2014 Posted April 22, 2014 (edited) From all I can tell there is nothing wrong with our code... The information shows up correctly during playback, so I think it may be on the XBMC side. xnappo thanks for looking into it after digging around a little more today and looking at the logs, you are correct, it looks like xbmb3c is passing the available info when the playback starts. i also tested with 2 different boxes and noticed that the first time i played any video, even if it was played on another box, would show the correct info, but after stopping and resuming on the box, some of the info is gone. when i delete the local MyVideosXX.db it gives me the full stread details.. it looks like when xbmc stores addon videos it plays, it doesnt store much info locally, and the next time it plays, it pulls the lacking local info.. will look around a little more, hopefully its just an issue with the current build im on. Edited April 22, 2014 by elcabong 1
tube82 73 Posted April 22, 2014 Author Posted April 22, 2014 Added special features suggestion and a link to the thread where it's discussed.
elcabong 48 Posted April 23, 2014 Posted April 23, 2014 there is an error on line 285 of default.py, the favorite show has sectype std.movies instead of std.tvshows. otherwise.. awesome.. sometimes you dont know how much youve been missing a feature til its there 1
tube82 73 Posted April 23, 2014 Author Posted April 23, 2014 Just read the following post in the XBMB3C thread on the XBMC forums: I just installed this, but i there seems to be no favorite TV shows...is this normal? There is favorite Movies and episodes but no TV shows. Really cant use this plugin without that because the wife just hates to have to scrool 200+ Tv shows and i had created a favorites in the MBS hoping to use it in xbmc. AFAIK there still isn't a favorite TV shows list node, right? I think it's a good suggestion. 1
tube82 73 Posted April 23, 2014 Author Posted April 23, 2014 After the recent fix it works correctly! 1
rsday75 0 Posted April 30, 2014 Posted April 30, 2014 I am using the MB3 XBMC Confluence Skin. In the origional XBMC, when you right click on a movie one of the menu choices is movie imfo. This seems to work if I hit "i" on the keyboard, but it would be nice to have in the right click menu for remote use. In the skin forum, they said this would have to be added to this addon. Not a huge deal, but I thought maybe here would be a good place to list the idea. Thanks, Randall
xnappo 1611 Posted April 30, 2014 Posted April 30, 2014 Yeah, I think that is reasonable to add. The context menu is getting really long though - need some ideas on consolidation. xnappo
tube82 73 Posted April 30, 2014 Author Posted April 30, 2014 Updated the first post with the new feature requests/suggestions
tube82 73 Posted May 4, 2014 Author Posted May 4, 2014 I wanted to add a few minor suggestions we discussed in various threads, so they don't get lost. In the Aeon Nox skin support thread we had a couple of things that are not really related to the skin but to XBMB3C itself: More refinement to the mapping of images MB3 <-> XBMB3C I had tried: extraData={'thumb' : getArtwork(item, "Primary") , 'fanart_image' : getArtwork(item, "Backdrop") , 'poster' : getArtwork(item, "poster") , 'tvshow.poster': getArtwork(item, "tvshow.poster") , 'banner' : getArtwork(item, "Banner") , 'clearlogo' : getArtwork(item, "Logo") , 'discart' : getArtwork(item, "Disc") , 'clearart' : getArtwork(item, "Art") , 'landscape' : getArtwork(item, "Thumb") , locally and got very good results. Currently 'landscape' uses the backdrop from MB3, which is not a good fit. In addition, 'landscape' and 'banner' have separate images for TV shows and seasons. Currently for both image types the TV show image is used in season views instead of the season images. Allow usage of additional images in widgets Currenlty, 'landscape' and 'clearart' images (and maybe others) can't be used in home screen widgets. In the window properties skin support thread I had the following suggestion: Additional properties for series/seasons ListItem.Property(UnWatchedEpisodes) ListItem.Property(TotalEpisodes) XBMC uses those two properties to display the number of total/unwatched episodes of a show or season.
xnappo 1611 Posted May 4, 2014 Posted May 4, 2014 I tried the landscape=thumb changes, both with and without the series are and it did not work well at all for me. Did you make any other changes? I can't get 'Thumb' to work at all - but am putting time into the rotating fanart rather than this. If you can make your mods to the latest Git that would be great. If you want to be an official dev on the it - just let me know your Git username! xnappo
tube82 73 Posted May 4, 2014 Author Posted May 4, 2014 (edited) Interesting. Maybe MB3 just doesn't have the necessary images for the views? A lot of movies lack the thumb images, so it's no view I would advice using for movies. What content did you try them on? Thumb and banner views for movies or on season levels are tricky because a lot of content doesn't have the images - that doesn't change the fact that it's the correct mapping though. A native XBMC runs into the same issues when using those views. When the user takes the time to create or find the images for the views they are really nice. Maybe it would be a good idea to use the show banner as a fallback if no season banner exists and to use the backdrop as a fallback when no thumb exists. But I strongly believe the first choice should be landscape=Thumb. I can commit my changes if you want. My git name is the same as my name here. I just tried the landscape views in the latest Aeon Nox version and I only get black images for 'landscape'. With and without my changes. Could it be you broke something with the rotation changes? The landscape images stil work with Arctic, so it seems to be a skin problem. Edited May 4, 2014 by tube82
xnappo 1611 Posted May 4, 2014 Posted May 4, 2014 Okay - yes I am use Aeon Nox - and am seeing the same as you. I don't *think* I touched that code - but it is certainly possible. I will play with it with unmodified Nox and see. xnappo
tube82 73 Posted May 4, 2014 Author Posted May 4, 2014 Here is a comparison of a landscape view without and with my changes in tv show level: https://drive.google.com/file/d/0B-iJnwQCTVZ4N08yb2owbnJTWm8/edit?usp=sharing https://drive.google.com/file/d/0B-iJnwQCTVZ4QnRLMFVxVTJnX2c/edit?usp=sharing and on season level: https://drive.google.com/file/d/0B-iJnwQCTVZ4d0dhUkIzY19hdk0/edit?usp=sharing https://drive.google.com/file/d/0B-iJnwQCTVZ4bnozQ21fclgwdU0/edit?usp=sharing
xnappo 1611 Posted May 4, 2014 Posted May 4, 2014 Okay - I confirmed I broke something when working on rotating art - I will get this one in there. xnappo
