Pog22 52 Posted November 6, 2018 Posted November 6, 2018 I downloaded the Android mobile app 3.0.21, with a lot of work i got it to install in the kids profile but it will not play any media. Am I out if luck with this or is there a version for the Kindle Fire 5th gen?
Pog22 52 Posted November 6, 2018 Author Posted November 6, 2018 What happens when you try to play media? I get this error
Luke 42244 Posted November 6, 2018 Posted November 6, 2018 Can you please attach the emby server log? Thanks.
Pog22 52 Posted November 6, 2018 Author Posted November 6, 2018 (edited) Can you please attach the emby server log? Thanks. embyserver.txt Edited November 6, 2018 by colfin22
Pog22 52 Posted November 6, 2018 Author Posted November 6, 2018 What time did you try to play? I sanitised my domin name out of the log Just a few mins ago. I enabled debugging and then tried to stream a few episodes
Luke 42244 Posted November 6, 2018 Posted November 6, 2018 What version of android does this run? Can you try this version and see how it compares: https://www.dropbox.com/s/9am2hgfcj403j8d/MediaBrowser.Mobile-googlearmv7-release.apk?dl=0 Thanks.
Pog22 52 Posted November 6, 2018 Author Posted November 6, 2018 Fireos 5.6.2.0 which I believe is Lollipop. I'll get that app on later and report back
Pog22 52 Posted November 6, 2018 Author Posted November 6, 2018 No, that did the same Luke From about 9.06 onwards in this log embyserver.txt
Pog22 52 Posted November 6, 2018 Author Posted November 6, 2018 ffmpeg-transcode-4643fdfb-a817-4f41-8c57-c4913c3c8417.txt
Pog22 52 Posted November 7, 2018 Author Posted November 7, 2018 Enabling the use of an external player works, but it requires a second click to play media
Pog22 52 Posted November 7, 2018 Author Posted November 7, 2018 (edited) Scratch that, there's no audio on any of the media unless the default is stereo Edit: installed VLC as the external player and now I get audio. This is not an ideal solution though as it's for a child Edited November 7, 2018 by colfin22
