Diedrich 380 Posted November 5, 2018 Posted November 5, 2018 Could someone help test a recording, please? 1. Set your recording for The Big Bang Theory on CBS @ 8:00pm this Thursday, make sure it says New Episodes Only and to not record if it’s in your library. 2. Now jump forward to Thursday the 15th and see if the timer is automatically set. Mine isn’t! 3. Go to the series tab and delete TBBT recording schedule task. 4. Go back to the Guide but this time go to Thursday the 15th and set the timer for TBBT. 5. Go to Thursday the 8th to see if TBBT is showing to be recorded. Mine isn’t! 6. Reply to this thread, please. Thanks!
Sammy 791 Posted November 5, 2018 Posted November 5, 2018 I've got both and have had them for some time now. I'm not sure what the issue is but I am not going to delete my scheduled recording to replicate. Have you tried scheduling the recording for November 8? Sent from my SM-G930P using Tapatalk
Diedrich 380 Posted November 5, 2018 Author Posted November 5, 2018 (edited) Because a single recording is not being triggered for both dates I have had to create two scheduled recordings. Edited November 5, 2018 by Diedrich
Diedrich 380 Posted November 5, 2018 Author Posted November 5, 2018 (edited) I am not going to delete my scheduled recording to replicate.What about Will & Grace at 9pm on NBC on Thursday, I have the same issue with that series as well. Edited November 5, 2018 by Diedrich
Sammy 791 Posted November 5, 2018 Posted November 5, 2018 What about Will & Grace at 9pm on NBC on Thursday, I have the same issue with that series as well.Will and Grace is only on 11/15 but The Voice is on 11/08. I scheduled the 11/15 showing without issue. Sent from my SM-G930P using Tapatalk
