mgworek 135 Posted November 5, 2018 Posted November 5, 2018 When I moved my server to a VM from docker, I forgot my Cinema Mode Custom Intos path needed to be update. I updated the paths this morning and ran a scan. I got an error for each intro. Based on the error, I thought it might fix itself on next scan but every scan has the same errors. Not sure what to do. Here is the line that stands out. "System.ArgumentException: System.ArgumentException: Can't refresh an item that hasn't been saved yet." Full error and log attached. "2018-11-05 10:12:20.064 Error App: Error refreshing intro /Media/Trailers/Codecs/DTS-HD HRA.mkv *** Error Report *** Version: 3.6.0.60 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.18.0.10 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.ArgumentException: System.ArgumentException: Can't refresh an item that hasn't been saved yet. 0 /Media/Trailers/Codecs/DTS-HD HRA.mkv at MediaBrowser.Providers.Manager.MetadataService`2.RefreshMetadata(BaseItem item, MetadataRefreshOptions refreshOptions, CancellationToken cancellationToken) at MediaBrowser.Controller.Entities.BaseItem.RefreshMetadata(MetadataRefreshOptions options, CancellationToken cancellationToken) at Emby.Server.CinemaMode.Tasks.RefreshIntrosScanTask.RefreshIntro(String path, CancellationToken cancellationToken) at Emby.Server.CinemaMode.Tasks.RefreshIntrosScanTask.Run(IProgress`1 progress, CancellationToken cancellationToken) Source: MediaBrowser.Providers TargetSite: Void MoveNext() at MediaBrowser.Providers.Manager.MetadataService`2.RefreshMetadata(BaseItem item, MetadataRefreshOptions refreshOptions, CancellationToken cancellationToken) at MediaBrowser.Controller.Entities.BaseItem.RefreshMetadata(MetadataRefreshOptions options, CancellationToken cancellationToken) at Emby.Server.CinemaMode.Tasks.RefreshIntrosScanTask.RefreshIntro(String path, CancellationToken cancellationToken) at Emby.Server.CinemaMode.Tasks.RefreshIntrosScanTask.Run(IProgress`1 progress, CancellationToken cancellationToken) " embyserver.txt
Solution mgworek 135 Posted November 6, 2018 Author Solution Posted November 6, 2018 (edited) Everything scanned correctly with 3.6.0.61 and with the updated Cinema Mode Plugin Thanks! Edited November 6, 2018 by mgworek
