jglazer63 23 Posted November 4, 2018 Posted November 4, 2018 So I have EMBY setup and running. I want to connect to it with my Windows box which is no problem though embycon. Now I want to get the menus to work like I am used to with the MYSQL setup. So when Kodi runs, I have Movies and TV. Right now I Have to go to Adons -> Emby -> Movies instead of just Movies. Is there a way to setup the same virtual functionality that Kodi had with the Estuary (or whatever) skin?Thanks!
hoppel118 37 Posted November 4, 2018 Posted November 4, 2018 (edited) This not possible with default Estuary. You have two possibilities: 1. Instead of default Estuary, you can use another skin, which has such a feature. With such a skin it is possible to link the EmbyCon Librarieries, where you need them. I use GRiD for example. I think it is also possible with Estuary Mod V2 and I read that Embuary has a great EmbyCon integration. Try it. 2. Instead of using „EmbyCon“ you can install „Emby for Kodi“. Emby for Kodi syncs to Kodi‘s default database. Regards Hoppel Edited November 4, 2018 by hoppel118
